03-06-2007, 13:39 | #1 (permalink) |
Registered User Join Date: Oct 2005 Location: Bangladesh
Member: 193729 Status: Offline Sonork: 100.1651149 Thanks Meter: 3 | c168 after flash no rington so what to do?please help. |
03-06-2007, 17:28 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, flash phone with original firmare. Also, to make phone really working it's need to write main + lp + images + melody + flex parts together. See documentation here: http://www.infinity-box.com/download...p?id_file=2743 |
03-07-2007, 11:34 | #3 (permalink) |
Member: 193729 Status: Offline Sonork: 100.1651149 Thanks Meter: 3 | no progress problem is as it is. with ur documentation i flashed the phone with both old and new files.and as described in documentation. the problem also appers as described.help please |
03-08-2007, 07:29 | #5 (permalink) |
Member: 193729 Status: Offline Sonork: 100.1651149 Thanks Meter: 3 | 1180,1190,1390,1480,1490 with the help of documentation.no problem with file selection.because of the problem i flashed with different file system and eeprom.just give a file with which my set willbe alive again. |
03-08-2007, 12:01 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Babul_BD Files sets in support area tested many times by many users. It can't be any problem with files, so please, try to flash phone again, select flash files according o manual, flash main + lp + melody + images + flex together. Also you can try to make reset. If no luck: check phone hardware. |
C168 after flashed same condition Restart | aukonline | Infinity-Box | 5 | 05-31-2007 20:28 |
c168 after flash no game sound | Amit Tank | Infinity-Box | 4 | 02-07-2007 05:49 |
x660 after flash no ringtone in galery. | Dyziaczek | UST Pro II | 0 | 10-27-2006 15:16 |
G5300i,after flash no ringtones | rambo amadeus | VygisToolbox | 5 | 01-05-2006 09:17 |
NEC n22i after flash no ringtones and images !! | chavrotti | Redbox | 1 | 06-29-2004 14:41 |
