01-08-2009, 15:16 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, open phone and post here CPU chip name. If you have PinFinder you can try to detect pinout in automatic mode (at first try to detect pinout like MT62xx). Let's see results and then we will be able to give you more advices. |
01-08-2009, 18:06 | #7 (permalink) |
No Life Poster Join Date: Nov 2005 Location: EingneeR
Member: 201469 Status: Offline Sonork: software Thanks Meter: 50 | i trying with pinfinder but not detect pinout i can use cable L10A (1 x 10 ) , L10C ( 2 x 5 ) i opening phone ice big M arm MT6228t ice small M MT6318a ice other samsung 731 k9f1608u0a-jib0 please support it thanks |
The Following User Says Thank You to muhned For This Useful Post: |
01-08-2009, 20:01 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, This phone can be supported. What ios phone connector type exactly ? Is it 1x10 or 2x5 pins ? Where is GND pin at phone connector ? Can you check PCB, probably you can find RX and TX test points at phone PCB. |
01-08-2009, 22:28 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, keyboard top connector 2x5 1 2 3 4 5 6 7 8 9 10 4: Box Tx/Phone Rx (RJ45 pin-2) 5: Box Rx/Phone Tx (RJ45 pin-3) 6: Gnd Try this pinout. Run "ChineseMiracle" software, select model "Autodetect MT6228" and try to read flash. Waiting or your results |
01-10-2009, 22:39 | #11 (permalink) |
Member: 201469 Status: Offline Sonork: software Thanks Meter: 50 | hi infinity i trying i use cable L10C COM5 [VCP1] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 10 sec Remove/Install battery now ! |
01-11-2009, 07:28 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It is for sure cable problem. Could you, please, check phone PCB, probably you can find RX and TX test points at phone PCB. Post here good quality phone PCB photo. |
10-21-2009, 23:07 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If required file can not be found in support area (please use "search" function in support area first) it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. Here is an instruction how to make "search" in support area: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files ! |
who want konka d266 pinout | sanjeewa57 | Infinity-Box | 11 | 11-05-2009 15:03 |
need konka d266 | sanjeewa57 | Infinity-Box | 10 | 10-26-2009 05:02 |
need konka d266 flash file | sanjeewa57 | Infinity-Box | 1 | 10-17-2009 18:39 |
need konka d266 flash file | sanjeewa57 | Chinese Models & Cloned Phones | 0 | 10-17-2009 15:47 |
06 Dec 2006: Konka A26M model supported | InfinitySupport | Infinity-Box | 6 | 01-19-2007 06:35 |
