12-04-2014, 13:32 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | KOREA BY SAMSUNG i9500 In Dead Condition. Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00008810 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447020FDB17629035 [eMMC] : FLASH_LEN : 0x00000000E2C00000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:12 Any Solution Please ? |
12-04-2014, 14:01 | #5 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Solution - collect all 10-15k NAND android chinese variants firmwares and by retrieve info from phone - select correct one |
The Following User Says Thank You to Dzirt For This Useful Post: |
