02-06-2009, 17:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: United Kingdom
Member: 109729 Status: Offline Thanks Meter: 36 | zte 125 new version? can't unlock, i try to flash phone and now is dead ==== log opened: [06.02.2009 17:34:29] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.61 S/N: xxxxxxx Wait... Device: ZTE-125 Ready Loading file v.02... ZTE-125_main_ERF-RO-P108A1V1.0.0B08__VDF-P108A1B07-RoFr-RO06_g3dBV2.0.B1M.bin loaded Loading file v.02... ZTE-125_LP_E-IN-P108A1V1.0.0B05_Jul-17-2007__VDF-P108A1B07-IN04_g3dBV2.0.B1P.bin loaded ==== log: [06.02.2009 17:36:45] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... sw version: -HU-P108A1V1.0.0B03 VDF-P108A1B07-Hu-HU02 g3dBV2.0 04.12.00 18.2 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-173709.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-173710.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-173732.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... error: set erase range error: reset failed Erasing: Firmware error: set erase range error: erase failed: 00400000 Write Failed Finished, time used: 54 sec Remove/Install battery now ! ==== log: [06.02.2009 17:37:50] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-173804.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-173804.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-173807.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 24 sec Remove/Install battery now ! ==== log: [06.02.2009 17:38:35] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-173857.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-173857.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-173859.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 30 sec Remove/Install battery now ! Loading file v.02... ZTE-125_eeprom-complete_20090206-173732.B1E.bin loaded ==== log: [06.02.2009 17:40:41] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write error: no data to write ! Loading file v.02... ZTE-125_eeprom-complete_20090206-173732.B1E.bin loaded ==== log: [06.02.2009 17:40:56] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-174116.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-174116.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-174118.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 24 sec Remove/Install battery now ! Loading file v.02... ZTE-125_repair_eeprom_complete_01.B1E.bin loaded ==== log: [06.02.2009 17:42:00] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-174218.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-174219.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-174221.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 22 sec Remove/Install battery now ! ==== log: [06.02.2009 17:42:39] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: read flash Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-174257.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-174257.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-174259.B1E.bin backup critical area Done Check memory ... reading flash... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_flash_20090206-174417.B1X.bin completed Finished, time used: 143 sec Remove/Install battery now ! Loading file v.02... ZTE-125_main_ED-DE-P108A1V1.0.0B02_Aug-13-2007__VDF-P108A1B07-De-DE03_g3dBV2.0.B1M.bin loaded Loading file v.02... ZTE-125_LP_ED-DE-P108A1V1.0.0B02_Aug-13-2007__VDF-P108A1B07-De-DE03_g3dBV2.0.B1P.bin loaded ==== log: [06.02.2009 17:45:48] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-174609.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-174610.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-174612.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 31 sec Remove/Install battery now ! Loading file v.02... ZTE-125_main_lp_EA-EG-P108A1V1.0.0B05_VDF-P108A1B07-Ar-EG04.B1M.bin loaded Loading file v.02... ZTE-125_LP_E-IN-P108A1V1.0.0B05_Jul-17-2007__VDF-P108A1B07-IN04_g3dBV2.0.B1P.bin loaded ==== log: [06.02.2009 17:46:54] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-174712.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-174713.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-174715.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 28 sec Remove/Install battery now ! Loading file v.02... ZTE-125_main_ERF-RO-P108A1V1.0.0B06__VDF-P108A1B06-RoFr-RO05.B1M.bin loaded Loading file v.02... ZTE-125_LP_ERF-RO-P108A1V1.0.0B06__VDF-P108A1B06-RoFr-RO05.B1P.bin loaded ==== log: [06.02.2009 17:47:49] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-174806.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-174806.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-174808.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 26 sec Remove/Install battery now ! Loading file v.02... ZTE-125_main_ERF-RO-P108A1V1.0.0B08__VDF-P108A1B07-RoFr-RO06_g3dBV2.0.B1M.bin loaded Loading file v.02... ZTE-125_LP_ERF-RO-P108A1V1.0.0B08__VDF-P108A1B07-RoFr-RO06_g3dBV2.0.B1P.bin loaded ==== log: [06.02.2009 17:48:34] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-174850.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-174851.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-174853.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 25 sec Remove/Install battery now ! ==== log: [06.02.2009 18:01:09] ==== COM2 [VCP0] selected module v1.61 Device: ZTE-125 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00BF:7343 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20090206-180128.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20090206-180128.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20090206-180130.B1E.bin backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 27 sec Remove/Install battery now ! |
02-07-2009, 09:34 | #3 (permalink) |
Member: 109729 Status: Offline Thanks Meter: 36 | ==== log opened: [07.02.2009 09:43:06] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.62 S/N: wwwwww Wait... Device: Digibee-BSNL-G200CF Ready Loading file v.02... ZTE125_main_ERF-RO-P108A1V1.0.0B06__VDF-P108A1B06-RoFr-RO05.B1M.bin loaded ==== log: [07.02.2009 09:44:03] ==== COM2 [VCP0] selected module v1.62 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write error: no data for FFS-2/File system ==== log: [07.02.2009 09:44:12] ==== COM2 [VCP0] selected module v1.62 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Failed Finished, time used: 15 sec Remove/Install battery now ! ==== log: [07.02.2009 09:44:39] ==== COM2 [VCP0] selected module v1.62 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Failed Finished, time used: 15 sec Remove/Install battery now ! ==== log: [07.02.2009 09:45:18] ==== COM2 [VCP0] selected module v1.62 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Failed Finished, time used: 24 sec Remove/Install battery now ! ==== log opened: [07.02.2009 10:28:30] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.62 error: Dongle is not found ==== log opened: [07.02.2009 10:29:06] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.62 S/N: xxxxxxxx Wait... Device: Digibee-BSNL-G200CF Ready error: can't open COM1 COM2 ready Loading file v.02... ZTE-125_main_ED-DE-P108A1V1.0.0B02_Aug-13-2007__VDF-P108A1B07-De-DE03_g3dBV2.0.B1M.bin loaded ==== log: [07.02.2009 10:29:48] ==== COM2 [VCP0] selected module v1.62 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Failed Finished, time used: 15 sec Remove/Install battery now ! ==== log: [07.02.2009 10:30:20] ==== COM2 [VCP0] selected module v1.62 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Failed Finished, time used: 19 sec Remove/Install battery now ! i |
01-27-2010, 15:22 | #6 (permalink) |
No Life Poster Join Date: Apr 2004 Location: nagaur raj Age: 57
Member: 62820 Status: Offline Thanks Meter: 175 | use this firmware file only single file not use lp or eaprom , during flash mark reset setting afte flash your set on tested after flash dead ZTE-125_main_lp_CELTEL-P108A11B01-EnFr-01.B1M.bin then unlock then write original imei |
01-28-2010, 10:16 | #9 (permalink) |
Freak Poster Join Date: Jan 2010 Location: punjab,india Age: 44
Member: 1212089 Status: Offline Thanks Meter: 123 | Vodafone zte 125 dead after full flash VODAFONE 125 WITH SIM ONLY VODAFONE LOGO & WITHOUT SIM SET IS COMPLETE ON.1ST TRY RESET PHONE SAME PROBLUM .AND 2ND TRY TO FULL FLASH PHONE IS DEAD ANY BODY HAVE SOLUTION .PLZ SHARE ME HERE IS LOG FILES ==== log: [1/28/2010 1:50:53 PM] ==== COM3 [VCP0] selected module v1.73 Device: ZTE-125 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: -IN-P108A1V1.0.0B05 Jul 17 2007 Jul 17 2007 09 48 59 09 48 59 VD Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20100128-135112.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20100128-135113.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20100128-135119.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 24 sec Remove/Install battery now ! Loading file v.02... ZTE-125_main_E-IN-P108A1V1.0.0B05_Jul-17-2007__VDF-P108A1B07-IN04_g3dBV2.0.B1M.bin loaded Loading file v.02... ZTE-125_LP_E-IN-P108A1V1.0.0B05_Jul-17-2007__VDF-P108A1B07-IN04_g3dBV2.0.B1P.bin loaded ==== log: [1/28/2010 1:52:49 PM] ==== COM3 [VCP0] selected module v1.73 Device: ZTE-125 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: -IN-P108A1V1.0.0B05 Jul 17 2007 Jul 17 2007 09 48 59 09 48 59 VD Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20100128-135308.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20100128-135309.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20100128-135316.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Write Done Finished, time used: 4 min 8 sec Remove/Install battery now ! |
01-28-2010, 16:26 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | 1. flash phone with this files: ZTE-125_main_E-IN-P108A1V1.0.0B05_Jul-17-2007__VDF-P108A1B07-IN04_g3dBV2.0.B1M.bin ZTE-125_LP_E-IN-P108A1V1.0.0B05_Jul-17-2007__VDF-P108A1B07-IN04_g3dBV2.0.B1P.bin 2. http://www.infinity-box.com/wiki/ind...ot_make_a_call |
zte f285 new version unloking | jeetendrasa | Various CDMA/TDMA Cell Phones | 2 | 11-16-2009 18:11 |
Added ZTE F866 new version unlock - LGQ133 | Gobi | VygisToolbox | 15 | 11-11-2009 08:47 |
zte F285 new version unlock Plz help | pareshlahade | Various CDMA/TDMA Cell Phones | 3 | 11-09-2009 08:29 |
VYGISTOOLBOX: Added ZTE F866 new version unlock - LGQ133 | Gobi | Service Products News & Updates | 0 | 04-02-2009 19:55 |
