kp 199 after done flash dead help infinty team kp 199 after done flash dead help when i flash this phone b4 flash phone is on and working good i want change lanuge then i flash this phone but after done flash not on phone is dead help me its urgent plzzzzz i m still waiting |
What was original phone firmware version ? |
but after flash gone dead plz give me link good flash files |
All KP199 files in support area is well tested. Try to flash phone with another firmware from support area, it may be that your phone hardware should be flashed with newer firmware file. |
sir log here |
sorry i lost logs sir help .............. |
Hello, I suggest you to flash phone with thee next firmware files: 1. KP199-00-V10h-404-00-APR-02-2009_KP199_PCB01_GPRS_MT6226_S01.7S7339IN00-003-R1G_En_Hi.B0M.bin 2. KP199-00-V10e-ARB-XX-APR-09-2009_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B0M.bin do not forget to check battery voltage !!! |
phonr not on with this filess chk log help me COM6 [VCP0] selected module v3.03 Device: LG-KP199 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware KP199-00-V10e-ARB-XX-APR-09-2009_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:6CC8:8B79 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is damaged, recalculation required rom info detection finished device-id: 4161132D rom info ver: 04 sw version: KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN project-id: 7S7339SA00-002-R1C, 65657A3B code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: LG-KP199_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C__ffs... file saved: C:\Program Files\InfinityBox\MModule\LG-KP199_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C__ffs_20100128-081730.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 3 sec Remove/Install battery now ! |
1. KP199-00-V10h-404-00-APR-02-2009_KP199_PCB01_GPRS_MT6226_S01.7S7339IN00-003-R1G_En_Hi.B0M.bin 2. KP199-00-V10e-ARB-XX-APR-09-2009_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B0M.bin |
hi, try to flash phone with another firmware files one by one. it may be that your phone has hardware that is compatible with one file only. you have to remember original firmware version (save operation log !!!!!) to avoid this kind of problems. also, try to make this operation: C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ LG-KG300_KG200_KG195_repair_freez_restart.txt |
