Old 01-21-2010, 15:27   #1 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 244
Question kp 199 after done flash dead help infinty team
when i flash this phone b4 flash phone is
on and working good i want change lanuge
then i flash this phone but after done flash
not on phone is dead help me its urgent plzzzzz
i m still waiting
Old 01-21-2010, 18:16   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,079
i m still waiting
Hello,
What was original phone firmware version ?
Old 01-23-2010, 14:45   #3 (permalink)
Member: 1149013
Thanks Meter: 244
Question
Originally Posted by InfinitySupport View Post
Hello,
i get from infinty support side this flash files
but after flash gone dead plz give me link good flash files
Old 01-23-2010, 15:00   #4 (permalink)
Member: 1149013
Thanks Meter: 244
Hello,
Old 01-23-2010, 15:01   #5 (permalink)
Member: 130995
All KP199 files in support area is well tested.
Try to flash phone with another firmware from support area, it may be that your phone hardware should be flashed with newer firmware file.
Old 01-24-2010, 14:38   #6 (permalink)
Member: 1149013
Thanks Meter: 244
Question
flash done with other files but not ok log here its not hardware
sir log here
Old 01-24-2010, 14:45   #7 (permalink)
Member: 1149013
Thanks Meter: 244
sorry i lost logs sir help ..............
Old 01-25-2010, 14:30   #8 (permalink)
Member: 130995
Hello,
I suggest you to flash phone with thee next firmware files:
1. KP199-00-V10h-404-00-APR-02-2009_KP199_PCB01_GPRS_MT6226_S01.7S7339IN00-003-R1G_En_Hi.B0M.bin
2. KP199-00-V10e-ARB-XX-APR-09-2009_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B0M.bin
do not forget to check battery voltage !!!
Old 01-28-2010, 15:19   #9 (permalink)
Member: 1149013
Thanks Meter: 244
Question
Hello,
phonr not on with this filess chk log help me
COM6 [VCP0] selected
module v3.03
Device: LG-KP199
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
chip: 0031:6CC8:8B79
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
====> Set baud ...
230400
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is damaged, recalculation required
rom info detection finished
device-id: 4161132D
rom info ver: 04
sw version: KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN
project-id: 7S7339SA00-002-R1C, 65657A3B
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
ffs/eeprom address assigned: 00E00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: LG-KP199_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C__ffs...
file saved: C:\Program Files\InfinityBox\MModule\LG-KP199_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C__ffs_20100128-081730.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Area: Firmware
Write: Firmware
sec info (fast) detection...
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 3 min 3 sec
Remove/Install battery now !
Old 01-28-2010, 15:19   #10 (permalink)
Member: 1149013
Thanks Meter: 244
Old 01-28-2010, 15:30   #11 (permalink)
Member: 1043909
Thanks Meter: 49,543
hi,
try to flash phone with another firmware files one by one. it may be that your phone has hardware that is compatible with one file only.
you have to remember original firmware version (save operation log !!!!!) to avoid this kind of problems.
also, try to make this operation: C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ LG-KG300_KG200_KG195_repair_freez_restart.txt
mtk 6230 flash türkçe help infinty team plsssss ibrahim_casper Infinity-Box 4 05-27-2010 00:33
kp 199 after done flash not on dead still Master Software Z3X-Team Products 1 01-21-2010 18:23
please help.. kp-105 after repair eeprom dead.. urgent residentdenuevo VygisToolbox 0 10-16-2009 17:09
1112 China flash file needed N1110 Please help Infinty team kabul Infinity-Box 2 04-14-2009 10:09
new phone cl71 , cf61 dead after flash please help infinity team ??? gadzetxp Infinity-Box 12 03-17-2007 11:56
Page generated in 0.36882 seconds with 8 queries
