07-23-2009, 16:36 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | KP 199 Dead After Flash... I Have Kp199 I Flash it for language change .. after flash it is dead... i got files from infinity server but not solved.... please if anyone have ok set then read flash files and give me ... i m thanks full to him |
The Following 2 Users Say Thank You to GsmUniversal For This Useful Post: |
07-25-2009, 12:57 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: IN mobile's
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | not a big deal 1st formate whole flash chip then flash with support areas file ur problem will solved 100% |
The Following User Says Thank You to robin25 For This Useful Post: |
07-25-2009, 15:45 | #4 (permalink) | |
KP199 files in support area has no problems. If you have a problem after flashing you must check battery voltage, check phone hardware, probably you need to flash phone with other firmware. | |
07-26-2009, 01:56 | #5 (permalink) | |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Quote:
I Think Firmware on Support Area is Not Okay... Anyone Have Another Tested Files So Give Me... | |
The Following User Says Thank You to GsmUniversal For This Useful Post: |
07-26-2009, 05:52 | #6 (permalink) |
Major Poster Join Date: Mar 2009
Member: 995637 Status: Offline Thanks Meter: 10 | i think infinity team have no stable selution yet abt kp199 flashing problem.pick a idea infinity team plz do sapret language flashing prucedure like nokia fones.or just put a button just for language flashing in menu. br |
07-26-2009, 09:04 | #7 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Just write imei from the back o f the set your set will be on its 100% tested by me (mode-3) z.k mobiles pakistan |
The Following 4 Users Say Thank You to zubairok For This Useful Post: |
07-26-2009, 12:52 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @basitmemon786 Flash files in Infinity-Box support area is absolutely perfect so you must explain what is the problem with phone so detailed as possible, post here operation log etc. What was original phone firmware version ? Do you see any errors duing flash process ? etc. etc. In other case your words like "not work" sounds really strange. @M o h s i n You are completely WRONG ! Infinity-Box has very good support for KP199, there is no any problems with files in support area. if you have any problem with KP199 you must make an explanation what is wrong exactly instead of write strange words like "no stable selution". If you have facts - post it here. if you want to talk about noting like "no stable selution" - it's better to be silent. As about your idea "flash LG like Nokia" and "button just for language flashing". Ideas is good... And we (Infinity-Box Team) have great experience with this idea more than 10 (ten) years already, but to make this "great idea" for KP199 you must contact to LG phone manufacturers and ask them to make separate language pack for their KP199 phones. Please, contact them as soon as possible and post here your results. We will be waiting for your results with impatience. |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
07-26-2009, 13:52 | #9 (permalink) |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | @zubairok Thankyou So Much ... Problem Solved @InfinitySupport Thanks Dear For Giving Reply... |
09-22-2009, 10:46 | #10 (permalink) |
Freak Poster Join Date: Jul 2008 Location: asdf
Member: 816948 Status: Offline Thanks Meter: 60 | infinitysupport plz help me lg kp199 flahing is ok but set not on set hardware is 1000% ok COM5 [VCP0] selected module v2.87 Device: LG-KP199 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware KP199-00-V10e-ARB-XX-APR-09-2009_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs LG-KP199_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C__ffs_20090922-131847.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:93B2:8485 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is damaged, recalculation required rom info detection finished device-id: BAC6E482 rom info protocol ver: 04 ver. sw 1: KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C.BIN ver. sw 2: 7S7339SA00-002-R1C, 65657A3B ffs offset/size: 00E00000/00200000 ffs address assigned: 00E00000 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: LG-KP199_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C__ffs... file saved: C:\Program Files\InfinityBox\MModule\LG-KP199_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-002-R1C__ffs_20090922-135525.B0E.bin Backup required data Done Patch required data ... Patch required data Done Special operation ... firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required Special operation Done Write ... Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware Area: Eeprom/ffs flash: 98004900000002:2AEA0000000000 Write: Eeprom/ffs detect device sec info... . detect device sec info finished Write Done Finalization ... ffs formatting... flash: 98004900000002:2AEA0000000000 Finalization Done Finished, time used: 241 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
09-23-2009, 15:50 | #11 (permalink) | |
Why you so sure that phone hardware is good ? Did you tried to flash phone with different firmware files ? | |
09-24-2009, 15:02 | #13 (permalink) |
Member: 816948 Status: Offline Thanks Meter: 60 | LG KP199 Dead after flashing yes i tried with different firmware files but i did not get reult ( the first problem in the set was of ring tone that selected ring tone was being change due to power off and on.then i format in infinity box and finally i full flashed set with version : kp199-00-v10e-ARB-XX-APR-09-2009-KP199-PCB01-GPR-MT6226_S01.7S7339SA00-002_RIC_En_Ru_Fr_Urdu_Farsi_Ar.B0M |
09-24-2009, 15:52 | #15 (permalink) | |
I suggest you to rehot/reball flash chip and CPU chip and then try to flash phone again. | |
6300 dead after flash 6233 dead after flash | mobileZONE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-27-2010 01:17 |
Dead 9210e Orange UK Dead after flashing :( | PhantomGSM | Trisha & Matrix Flasher | 4 | 05-06-2009 12:02 |
plz help kp 215 dead after try flashing | R@jusat | Infinity-Box | 4 | 03-04-2009 15:15 |
