11-30-2009, 13:00 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In My Laptop Age: 16
Member: 541117 Status: Offline Sonork: .::100.1586906::. Thanks Meter: 173 | KP 320 flash error before flash condition was stuck on kp320 logo Code: COM13 [VCP0] selected module v2.75 Device: LG-KP320 Checking data, wait... Action: write NAND flash read mode: 01 "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN ver. sw 2: 7S7610SA00-002-R1C, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok end mark #4 found nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6229:8A02:8A02]... CPU: MT6229 chip: 0031:2001:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 09 loader: 3.0840.00.00 NAND id: 98F19095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 external ram: 00000000 finalize connection... done emi configuration... ram size: 02000000 emi configuration done ram test... pass 1... pass 2... pass 3... pass 4... done NOR: 0000:000000000000 [00000000] NAND: 0098:00F100900095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... detecting bootloader structure... source data: page only identification#1 protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN ver. sw 2: 7S7610SA00-002-R1C, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok detecting bootloader structure by source file... source data: page only identification#1 protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN ver. sw 2: 7S7610SA00-002-R1C, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.75, database date: 15.05.2009): A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished Identification Done Write ... 00006000 bytes sent write core area 1 of 3... error: code: A500000BF1 error: code: 5A error: code: A500 error: code: error: block/offset: 00000906/00241800 error: can't write nand core Write Fail Finished, time used: 367 sec Remove/Install battery now ! Code: COM13 [VCP0] selected module v2.94 Device: Autodetect 6228-6229 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware KP320-00-V10g-CIS-XX-APR-17-2009_A7610_07A_PCB03_GPRS_MT6229_S02[1].7S7610RU00-001-R1Z_En_Ru_Kz_Ua.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only rom info protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610RU00-001-R1Z.BIN ver. sw 2: 7S7610RU00-001-R1Z, 00000000 address offset: 00000000 ffs offset/size: 02000000/06000000 id-page2 area is found, ROM3 extracted nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6229:8A02:8A02]... CPU: MT6229 high speed boot On chip: 0031:2001:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 09 loader: 3.0840.00.00 NAND id: 98F19095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 external ram: 00000000 finalize connection... done load emi configuration... apply emi configuration... ram size: 02000000 emi configuration done NOR: 0000:000000000000 [00000000] NAND: 0098:00F100900095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... detecting bootloader structure (chip)... source data: page only rom info protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN ver. sw 2: 7S7610SA00-002-R1C, 00000000 address offset: 00000000 ffs offset/size: 02000000/06000000 warning: id-page1 area is invalid nfi area detection finished: failed detecting bootloader structure (source file)... source data: page only rom info protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610RU00-001-R1Z.BIN ver. sw 2: 7S7610RU00-001-R1Z, 00000000 address offset: 00000000 ffs offset/size: 02000000/06000000 nfi area detection finished: Ok rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished startup code area #1 check... startup code area #1 fixed Identification Done Write ... 00006000 bytes sent write core area 1 of 3... 00419000 bytes sent write core area 2 of 3... 00B5A000 bytes sent write core area 3 of 3... error: code: A500000BF1 error: code: 5A error: code: A50000 error: code: error: block/offset: 00000000/00000000 error: can't write nand core Write Fail Finished, time used: 1628 sec Remove/Install battery now ! any more hints |
11-30-2009, 13:04 | #2 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
problem in flash chip | |
11-30-2009, 16:09 | #5 (permalink) |
Member: 541117 Status: Offline Sonork: .::100.1586906::. Thanks Meter: 173 | same with the new Mmadule 2.96 Code: COM13 [VCP0] selected module v2.96 Device: LG-KP320 Checking data, wait... Action: write NAND flash read mode: 01 "format ffs" active write: Firmware KP320-00-V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02[1].7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch sp-lock #0/0 is not required firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required source data: page only rom info protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN ver. sw 2: 7S7610SA00-002-R1C, 00000000 address offset: 00000000 ffs offset/size: 02000000/06000000 id-page2 area is found, ROM3 extracted nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6229:8A02:8A02]... CPU: MT6229 chip: 0031:2001:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 09 loader: 3.0840.00.00 NAND id: 98F19095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 external ram: 00000000 finalize connection... done load emi configuration... apply emi configuration... ram size: 02000000 emi configuration done NOR: 0000:000000000000 [00000000] NAND: 0098:00F100900095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... detecting bootloader structure (chip)... source data: page only rom info protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610RU00-001-R1Z.BIN ver. sw 2: 7S7610RU00-001-R1Z, 00000000 address offset: 00000000 ffs offset/size: 02000000/06000000 warning: id-page1 area is invalid nfi area detection finished: failed detecting bootloader structure (source file)... source data: page only rom info protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN ver. sw 2: 7S7610SA00-002-R1C, 00000000 address offset: 00000000 ffs offset/size: 02000000/06000000 nfi area detection finished: Ok rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished startup code area #1 check... startup code area #1 fixed Identification Done Write ... 00006000 bytes sent write core area 1 of 3... 00419000 bytes sent write core area 2 of 3... error: code: A500000BF1 error: code: 5A error: code: A500 error: code: error: block/offset: 000005C2/005C2000 error: can't write nand core Write Fail Finished, time used: 1077 sec Remove/Install battery now ! br |
03-16-2010, 12:29 | #7 (permalink) |
Freak Poster Join Date: Apr 2008 Location: pakistan (haveli lakha)
Member: 748223 Status: Offline Thanks Meter: 22 | kp320 flash err COM16 selected module v3.25 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10g-CIS-XX-APR-17-2009_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610RU00-001-R1Z_En_Ru_Kz_Ua.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610RU00-001-R1Z.bin nfi area detection finished: Ok interface: BROM_DLL_v3.936.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7610AA00-001-R1D detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610AA00-001-R1D.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610AA00-001-R1D.BIN project-id: 7S7610AA00-001-R1D, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.25, database date: 11.03.201): A7610_07A_PCB03_GPRS_MT6229_S02.7S7610AA00-001-R1D.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610RU00-001-R1Z.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 41 sec Remove/Install battery now ! |
04-07-2010, 18:44 | #9 (permalink) |
Freak Poster Join Date: Jan 2006 Location: with SPEED TECHNO
Member: 218791 Status: Offline Thanks Meter: 35 | COM21 [VCP2] selected module v3.03 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok "format ffs" active interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6229:8A02:8A02 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND warning: NOR flash chip is not installed NAND flash chip: S_DONE flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT flash size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00020000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_NAND_FLASH_BOOT bootcode current/expected: 3.2, 3.2 done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7610IN00-001-R2R detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND)... nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610IN00-001-R2R.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610IN00-001-R2R.BIN project-id: 7S7610IN00-001-R2R, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... error: can not write flash: 0FAE:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAE:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 28 min 16 sec Remove/Install battery now ! |
04-07-2010, 20:23 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @SOFT GSM Latest MModule software version is 3.33 Did you tried to use it ? |
04-08-2010, 10:18 | #11 (permalink) |
Member: 218791 Status: Offline Thanks Meter: 35 | i reflash with same modul and all same but obly i chage batterie for kp100 this is log : COM21 [VCP0] selected module v3.03 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6229:8A02:8A02 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND warning: NOR flash chip is not installed NAND flash chip: S_DONE flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT flash size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00020000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_NAND_FLASH_BOOT bootcode current/expected: 3.2, 3.2 done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7610SA00-002-R1C detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND)... nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin warning: id-page1 area is invalid nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN project-id: 7S7610SA00-002-R1C, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... Disconnect... done Finished, time used: 34 min 10 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to SOFT GSM For This Useful Post: |
05-08-2010, 15:08 | #12 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | Same kind of issue wid me Quote:
Lg.kp-320 (restart-freez) problem sovled | sajidashraf | Infinity-Box | 1 | 04-30-2009 21:49 |
kp 320 imei change? | bilal_mobile | Infinity-Box | 5 | 04-17-2009 12:23 |
need kp 320 pinouts | bilal_mobile | Infinity-Box | 1 | 04-03-2009 00:30 |
Kp-320 pinout here | sajidashraf | Infinity-Box | 2 | 04-02-2009 16:07 |
I Need L.G KP-320 Usb Driver ..? | communication_expert | LG | 1 | 03-17-2009 02:48 |
