09-29-2010, 13:07 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello, looks like you are post in wrong section. If you Infinity Box user - please, post it in main Infinity section - it will be more better and you receive answer more faster. BR |
09-29-2010, 21:45 | #3 (permalink) | |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software | |
kp100 unlock help me | bozogsm | LG | 3 | 11-14-2009 02:32 |
17/04/08 LG KE520/KE590/KM500/KP100/KP105/KP106 Full Support Added ! | .:hack3r2k:. | FuriousGold | 110 | 06-15-2009 19:48 |
Kp100 | GSMFLASCH | FuriousGold | 2 | 04-28-2008 16:24 |
LG KP100 not supported but it can be | fethi | Infinity-Box | 1 | 04-27-2008 21:03 |
NEW: Full support for KP100,KP105 and KP106 | Gobi | VygisToolbox | 23 | 04-11-2008 21:04 |
