12-05-2008, 10:53 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | KP100 just 14 sec direct unlock method #2 (Airtel etc.) ==== log: [12/4/2008 9:29:58 PM] ==== COM8 [VCP0] selected module v1.57 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL 2008-03-06 1.0 TMO_UK KP100 01 FL 44 V10a 234-30 M Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20081204-213012.B1E.bin loading data... data loaded imei: xxxxxxxxxxxxxxxxx reading eeprom-security_3558820236099xxxx... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202360991200_20081204-213012.B1E.bin reading eeprom-complete_35588202360991200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_3558820236099xxxx_20081204-213014.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to srkhan For This Useful Post: |
12-05-2008, 18:02 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @srkhan Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
unlock samsung min in just 2 sec. | king_of_rajasthan | Various CDMA/TDMA Cell Phones | 20 | 02-07-2010 08:08 |
n96 unlock with mxkey just some sec | unlock & flash | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 11-26-2009 11:48 |
After 14 sec ... error and close application 3.3 | alerene | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 11-25-2009 12:31 |
Can I unlock an LG KP100 just with software? | SuzyNightAngel | LG | 2 | 03-01-2009 01:03 |
BlackBerry <><> Just 10 sec-to unlock<><>ITS TIME TO BUY <><>ALL INSTANT | Fones_Clinic_Network | Main Sales Section | 0 | 12-12-2008 19:24 |
