10-27-2008, 10:10 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: PK, Remote Unlocking Services,
Member: 558087 Status: Offline Sonork: 100.1579413 Thanks Meter: 332 | use ke500 cable _ download flash file & do flash ,, |
The Following User Says Thank You to gujjar_brothers For This Useful Post: |
10-27-2008, 11:54 | #4 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | which file you have selected to flash?? and post with log!!! |
The Following User Says Thank You to msashami For This Useful Post: |
10-27-2008, 12:59 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | thanks for your replies i've Rewrite Eeprom from back up now it's in perviews position now it says sim error i read the code when i try to unlock it via code it says code error retry in count 0 here is the log too COM4 [VCP4] selected Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL Greece Open KP100 00 30 V10c 202-XX MAR-05-2008 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081027-175520.B1E.bin loading data... data loaded imei: 35996101XXXXXX200 reading [eeprom-sec_35996101XXXXXX200]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101244020200_20081027-175525.B1E.bin reading [eeprom-complete_35996101244020200]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101244020200_20081027-175533.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 90752208( this code is not working ) Finished, Remove/Install battery now ! Time used: 29 sec Last edited by kasrawiz; 10-27-2008 at 13:05. |
10-27-2008, 13:14 | #6 (permalink) |
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | this method worked out thanks to Infinity and To all who replied me COM4 [VCP4] selected Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL Greece Open KP100 00 30 V10c 202-XX MAR-05-2008 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081027-181017.B1E.bin loading data... data loaded imei: 35996101244020200 reading [eeprom-sec_35996101244020200]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101244020200_20081027-181021.B1E.bin reading [eeprom-complete_35996101244020200]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101244020200_20081027-181028.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 31 sec |
The Following User Says Thank You to kasrawiz For This Useful Post: |
10-27-2008, 18:29 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Lg kp100 problem with unlock [Closed] | iliya _angelov | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 16 | 05-07-2012 12:05 |
kp100 unlock problem | abumu3ed | FuriousGold | 9 | 03-26-2011 11:25 |
Problem with Kp100 | sonkar | FuriousGold | 10 | 04-13-2009 09:15 |
lg kp100 problem after flash | szmit4 | FuriousGold | 11 | 09-02-2008 11:25 |
KP100 problem after reading code!?!? | et.com | FuriousGold | 5 | 05-29-2008 19:44 |
