Kp100 sim error solution i have kp100 locked to boygues tele fr 1 test with read codes but give sim error Code: COM5 [VCP0] selected Code: COM5 [VCP0] selected Code: COM5 [VCP0] selected |
realy good effort and thanks for test report BR;) MapleGsm(umer) |
@youssef70 Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
good work!!! tested by me and it works thanks |
thanks thanks dear for nice information..................................... |
Hi very good.solution 100% working. BR Pars-GSM |
Thanks............ for good informations |
amaising THNX!!!!......................................... |
Hi very good.solution 100% working. BR denny86 |
yes 100% working solution.................................i tested ......... |
i also tested more time it is old story |
COM10 [VCP1] selected Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL KP100 VODAFONE DE 01 FL 49 V10a 262-02 AUG-21-2008 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20090504-021757.B1E.bin loading data... data loaded imei: 35588202646199800 reading [eeprom-sec_35588202646199800]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35588202646199800_20090504-021759.B1E.bin reading [eeprom-complete_35588202646199800]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202646199800_20090504-021802.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 29 sec |
