10-14-2008, 09:50 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: SBZ-TUNISIA Age: 54
Member: 104036 Status: Offline Thanks Meter: 44 | Kp100 sim error solution 1 test with read codes but give sim error Code: COM5 [VCP0] selected Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL BYT FR KP100 01 FL 208 V10b 208-20 APR-11-2008 +0 ^ Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081014-100022.B1E.bin loading data... data loaded imei: 35996101837446200 reading [eeprom-sec_35996101837446200]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101837446200_20081014-100027.B1E.bin reading [eeprom-complete_35996101837446200]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101837446200_20081014-100030.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 33158866 Finished, Remove/Install battery now ! Time used: 22 sec Code: COM5 [VCP0] selected Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL BYT FR KP100 01 FL 208 V10b 208-20 APR-11-2008 +0 ^ Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081014-100236.B1E.bin loading data... data loaded imei: 35996101837446200 reading [eeprom-sec_35996101837446200]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101837446200_20081014-100239.B1E.bin reading [eeprom-complete_35996101837446200]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101837446200_20081014-100242.B1E.bin backup critical area Done Check memory... loading data... data loaded loading data... data loaded loading data... data loaded loading data... data loaded code: 33158866 Check memory Done Write... Erasing: eeprom-sta Writing: eeprom-sta Write Done Finished, Remove/Install battery now ! Time used: 20 sec Code: COM5 [VCP0] selected Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL BYT FR KP100 01 FL 208 V10b 208-20 APR-11-2008 +0 ^ Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081014-103610.B1E.bin loading data... data loaded imei: 35996101837446200 reading [eeprom-sec_35996101837446200]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101837446200_20081014-103640.B1E.bin reading [eeprom-complete_35996101837446200]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101837446200_20081014-103644.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 50 sec Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Repair imei... software version: KP100FL-01-V10b-208-20-APR-11-2008+0 original imei: 35996101837446200 new imei: 35996101837446 imei verification Ok Done Finished |
The Following 6 Users Say Thank You to youssef70 For This Useful Post: |
10-14-2008, 13:49 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @youssef70 Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
05-04-2009, 09:22 | #12 (permalink) |
Junior Member Join Date: Jul 2007
Member: 541572 Status: Offline Thanks Meter: 4 | COM10 [VCP1] selected Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL KP100 VODAFONE DE 01 FL 49 V10a 262-02 AUG-21-2008 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20090504-021757.B1E.bin loading data... data loaded imei: 35588202646199800 reading [eeprom-sec_35588202646199800]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35588202646199800_20090504-021759.B1E.bin reading [eeprom-complete_35588202646199800]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202646199800_20090504-021802.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 29 sec |
05-11-2010, 06:36 | #13 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: Mombasa Age: 48
Member: 722683 Status: Offline Thanks Meter: 33 | Quote:
The Following User Says Thank You to hillagesa For This Useful Post: |
kp100-kp105 hardwear solution | gul_hassan528 | LG Hardware Repair | 42 | 02-18-2012 12:21 |
Full Solution For Lg Kg270 For No Service After Flash+Insert SIm error. | sahil00150 | Infinity-Box | 15 | 02-09-2011 15:55 |
Need E900 SIM way solution | Sardordec | Samsung Hardware Repair | 2 | 03-29-2010 22:24 |
Lg kp100 sim card error repair done by polar:::ENJOY::: | FullFLASHgSMPH | PolarBox 3 | 1 | 01-11-2009 02:16 |
LG k275 Sim Card Error solution | claudeoscar | LG | 0 | 09-10-2008 04:55 |
