Old 10-03-2008, 23:16   #1 (permalink)
youssef70's Avatar
Member: 104036
Thanks Meter: 44
KP100 unlock ok
COM5 [VCP0] selected
Device: LG-KP100
Checking data, wait...
Action: unlock
read unlock codes
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
460800
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
sw version: ULC2GL SUNRISE KP100 01  FL XXX V10a 228-02   APR-14-2008 +0   ^
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081003-182229.B1E.bin
loading data...
data loaded
imei: 35996101836130300
reading [eeprom-sec_35996101836130300]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101836130300_20081003-182232.B1E.bin
reading [eeprom-complete_35996101836130300]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101836130300_20081003-182235.B1E.bin
backup critical area Done
Check memory...
loading data...
data loaded
code: 64791587
Finished, Remove/Install battery now !
Time used: 19 sec
The Following User Says Thank You to youssef70 For This Useful Post:
Old 10-05-2008, 18:10   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
kp100 and huawei T158 unlock ok... ZIYAAD STRYKER Infinity-Box 0 02-14-2009 05:41
LG KP100 Unlock OK Amir-SkillZ Infinity-Box 0 08-12-2008 08:21
Kp100 unlock ok VIA Kg375 abumu3ed Multi-Box 11 07-24-2008 05:05
Page generated in 0.14990 seconds with 10 queries
