04-22-2009, 06:53 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Cavite,Philippines
Member: 710668 Status: Offline Thanks Meter: 121 | kp100 unlock pdoblem............. unlocking kp100 error... is it cable or new security?.... COM3 [VCP0] selected module v1.65 Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... error: can't run preloader: boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Failed Finished, time used: 14 sec Remove/Install battery now ! |
04-22-2009, 06:55 | #2 (permalink) | |
Try to use 115200 baudrate instead of 921600. | |
04-22-2009, 06:57 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
10% battery also u can try to lower the speed and try again | |
The Following User Says Thank You to deepakgarg For This Useful Post: |
04-23-2009, 23:32 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
kp100 unlock problem | abumu3ed | FuriousGold | 9 | 03-26-2011 11:25 |
kp100 unlock help me | bozogsm | LG | 3 | 11-14-2009 02:32 |
KP100 unlock problem | PEREPELKINE | VygisToolbox | 5 | 08-05-2008 17:44 |
Kp100 unlock ok VIA Kg375 | abumu3ed | Multi-Box | 11 | 07-24-2008 05:05 |
Kp100 unlock ererr | ajmal007 | Infinity-Box | 1 | 05-27-2008 00:49 |
