08-03-2010, 09:53 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Inside Boxes
Member: 228871 Status: Offline Thanks Meter: 43 | Kp106 b Unlock problem Also tried to unlock with all the methods but does not accepts the card. The set was unlocked and the only problem was it restarts when message option is opened. Please help team Thanks |
08-03-2010, 11:14 | #2 (permalink) | |
Please, try to unlock phone once again with different methods and post here operation log so we will be able to check it. | |
08-03-2010, 12:31 | #3 (permalink) |
Member: 228871 Status: Offline Thanks Meter: 43 | Here's the log ==== [8/3/2010 4:54:29 PM] ==== COM3 [VCP0] selected module v1.78 Device: LG-KP106 Checking data, wait... Action: "sp-unlock" read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL BRAZIL CLARO KP106b 01 FL 55 V10a 724-05 DEC-03-20 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-static_20100803-165446.B1E.bin loading data... data loaded imei: 35541403801160100 reading eeprom-security_35541403801160100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-security_35541403801160100_20100803-165448.B1E.bin reading eeprom-complete_35541403801160100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-complete_35541403801160100_20100803-165454.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 00000000 Finished, time used: 22 sec Remove/Install battery now ! ==== [8/3/2010 4:55:26 PM] ==== COM3 [VCP0] selected module v1.78 Device: LG-KP106 Checking data, wait... Action: "sp-unlock" direct unlock method #1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL BRAZIL CLARO KP106b 01 FL 55 V10a 724-05 DEC-03-20 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-static_20100803-165542.B1E.bin loading data... data loaded imei: 35541403801160100 reading eeprom-security_35541403801160100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-security_35541403801160100_20100803-165543.B1E.bin reading eeprom-complete_35541403801160100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-complete_35541403801160100_20100803-165550.B1E.bin backup critical area Done Check memory ... loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... data loaded code: 00000000 error: not locked or unknown eeprom Check memory Failed Finished, time used: 21 sec Remove/Install battery now ! ==== [8/3/2010 4:56:22 PM] ==== COM3 [VCP0] selected module v1.78 Device: LG-KP106 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL BRAZIL CLARO KP106b 01 FL 55 V10a 724-05 DEC-03-20 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-static_20100803-165638.B1E.bin loading data... data loaded imei: 35541403801160100 reading eeprom-security_35541403801160100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-security_35541403801160100_20100803-165639.B1E.bin reading eeprom-complete_35541403801160100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-complete_35541403801160100_20100803-165645.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 23 sec Remove/Install battery now ! |
The Following User Says Thank You to That'sme For This Useful Post: |
08-03-2010, 14:29 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, What is exact text that you can see at phone LCD when you power-on phone with wrong sim card ? Did you tried to test phone with another sim cards ? What is the results ? |
08-05-2010, 06:32 | #9 (permalink) |
Member: 228871 Status: Offline Thanks Meter: 43 | The solution did work Here is the success log... ==== [8/5/2010 10:21:26 AM] ==== COM3 [VCP0] selected module v1.78 Device: LG-KP106 Checking data, wait... Action: write flash write: Firmware KP105_KP100_P16-00-ESA_V10b_ESA-XX_DEC-27-2007+0_firmware_lp.B1M.bin skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system skip: Eeprom Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL BRAZIL CLARO KP106b 01 FL 55 V10a 724-05 DEC-03-20 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-static_20100805-102144.B1E.bin loading data... data loaded imei: 35541403801160100 reading eeprom-security_35541403801160100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-security_35541403801160100_20100805-102145.B1E.bin reading eeprom-complete_35541403801160100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP106_eeprom-complete_35541403801160100_20100805-102152.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 7 min 11 sec Remove/Install battery now ! Regards |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
