05-27-2008, 07:13 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Philippines
Member: 351593 Status: Offline Thanks Meter: 41 | KP130...revive by latest update of INFINITY MY INfinity strikes again...and save me for a compromise...... unit: KP130 lock to Tmobile action : Try to unlock via Pstool crack.....unlocked but sadly not poweded on after the process.. after waiting for update of Infinity..and flashed firmware from support... now my Kp130 are alive and unlock... heres how.. Pinouts used 17 - RX (data to phone) 16 - TX (data from phone) 1,4,14,18 - GND just follow tx document from support go to"Flash" page: "Firmware (code)": checked "File system": un-checked "Alchemy data": un-checked "Eeprom": un-checked Load full flash file via "Load Firmware (code)" button "Format FFS": un-checked "Smart write": checked "Keep calibration area": un-checked youre great Infinity team Thanks a lot .. more power jaytrio |
The Following 3 Users Say Thank You to jaytrio For This Useful Post: |
05-31-2008, 17:59 | #4 (permalink) |
No Life Poster Join Date: Mar 2004 Location: uk Age: 54
Member: 59789 Status: Offline Thanks Meter: 16 | log file for LG KP130 COM5 [VCP0] selected Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352126023389569 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126023389569_LG KP130_20080531-172148.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126023389569 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 103 sec Remove/Install battery now ! thanks infinty keep up the good work peace. |
06-14-2008, 08:39 | #5 (permalink) |
Insane Poster Join Date: Apr 2008
Member: 755760 Status: Offline Sonork: 852014 Thanks Meter: 11 | unlocking LG KP130 1--------18 17 rx 16 tx 1 gnd COM6 [VCP0] selected Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 3-------------------- file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126023389569_LG KP130_20080531-172148.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 3-------------------- ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 103 sec Remove/Install battery now ! phone is 110% unlock |
U830 is it supported by latest update??? | byteforce | Easy-Unlocker | 2 | 12-09-2008 14:59 |
full installation and latest update for infiniti-box | HZZORY4GSM | Infinity-Box | 8 | 09-22-2008 19:11 |
Nokia 6103 dead after imei repair, done with latest update of UB !!! | DJiCE | Universalbox | 3 | 07-25-2008 02:21 |
server not found ( i am using latest update of seetol) | mobileunlockers | SETool2 | 4 | 06-21-2008 06:34 |
Problem with latest update of Lg | sonkar | FuriousGold | 3 | 08-27-2007 14:48 |
