07-17-2008, 08:12 | #8 (permalink) |
Insane Poster Join Date: Aug 2005 Location: BANGLADESH Age: 50
Member: 170700 Status: Offline Thanks Meter: 8 | Lg Kp 130 100% Unlock Infinity-box Current device: LG KP130 Testing COM3 at 921600... COM3 [VCP0] selected Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 39 sec Remove/Install battery now ! Testing COM3 at 460800... COM3 [VCP0] selected Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 460800 Set baud Done Check flash... current eeprom imei: 352126024090380 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126024090380_LG KP130_20080717-125505.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126024090380 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 63 sec Remove/Install battery now ! |
07-17-2008, 14:13 | #9 (permalink) |
Junior Member Join Date: Apr 2008
Member: 739600 Status: Offline Thanks Meter: 6 | nokia e50 hi dear plz help .du u no how to add registar in flahsing cabel for nokia e50 plz reply [email protected] |
07-18-2008, 11:12 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @mohin_ic Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. @anmol taskeen What you talk about ? |
>>> E200 unlock ok <<< | keaelite | HWK | 0 | 08-01-2008 07:10 |
>>> T250i unlock ok in infinity <<< | keaelite | Infinity-Box | 2 | 06-27-2008 09:40 |
>>> CF75 unlock ok <<< | keaelite | FuriousGold | 0 | 05-09-2008 06:52 |
>>> CE110 unlock ok but phone still locked <<< | keaelite | FuriousGold | 11 | 05-04-2008 19:51 |
