Old 12-04-2009, 13:16   #1 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
Lg KP170 flash & unlock failed.
hello infinity team, i am trying to unlock lg kp170. log shows unlock ok but phone still locked.
COM2 [VCP0] selected
module v1.39
Device: LG-KP170 (under test)
Checking data, wait...
Action: unlock
unlock method: standard
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E223C2200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 350305260000001
file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20091204-173803.B1E.bin
Check flash Done
Check space ...
finalization done
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Finished, time used: 55 sec
Remove/Install battery now !
software show different imei from phones imei
i also tried to flash phone but always error after writing 7% .i attached log here
The Following User Says Thank You to himanshu taldar For This Useful Post:
Old 12-04-2009, 17:01   #2 (permalink)
Member: 243881
Thanks Meter: 68
yes bro i have same problem unlock ok i use button resat/formating but imei
current eeprom imei: 350305260000001 show
no network whan i check imei nomber *#06# imei 000000000000000
any solution
Infinity-tem ?????????????????????????????????????????????????? ????
Old 12-04-2009, 17:05   #3 (permalink)
GFTELECOM's Avatar
Member: 922273
Sonork: 100.1583612
Thanks Meter: 119
this model is under test wait for update
Old 12-05-2009, 09:30   #4 (permalink)
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
infinity team please reply.
Old 12-05-2009, 13:39   #5 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
does infinity support KP170 ;s
Old 01-10-2010, 12:28   #6 (permalink)
gsm_'s Avatar
Member: 991620
Thanks Meter: 429
Old 01-10-2010, 13:14   #7 (permalink)
gsm_'s Avatar
Member: 991620
Thanks Meter: 429
Old 01-15-2010, 10:53   #8 (permalink)
Member: 243881
Thanks Meter: 68
Old 02-04-2010, 17:13   #9 (permalink)
Member: 779470
Sonork: Waseem mobile
Thanks Meter: 101
Old 02-23-2010, 16:03   #10 (permalink)
Member: 25320
Thanks Meter: 11
i have same problem whit KP170
stops flash at 7% and gives eror
please infinity team fix this
The Following User Says Thank You to borkoi For This Useful Post:
Old 02-24-2010, 05:08   #11 (permalink)
Member: 468346
Thanks Meter: 4
hwk box repair 100% ok brother
Old 02-24-2010, 05:11   #12 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
only unlock make sure that we need full back imei first
Old 02-26-2010, 02:00   #13 (permalink)
baooshe2's Avatar
Member: 717872
Sonork: 100.1589423
Thanks Meter: 22
u can unlock kp170 reset setting,format ffs .test 1000000000%
LG-KC910i FLASHED & UNLOCKED OK allal123 VygisToolbox 2 02-11-2010 03:57
video LG 3G Flashing & unlock kabul SETool2 1 02-09-2010 08:43
LG KP170 flash and unlock report Proxy Z3X-Team Products 1 12-22-2009 22:35
LG KP170 Flashing gsmstars FuriousGold 2 11-20-2009 11:07
can i unlock lg kp170 with easy unlocker plz help? asif_ae Easy-Unlocker 1 02-23-2009 14:14
Page generated in 0.20957 seconds with 10 queries
