Old 03-13-2010, 09:17   #1 (permalink)
thushdt's Avatar
Member: 544160
Sonork: 100.1603100
Thanks Meter: 178
Chinese Phone Dead after Format
I have Cesim Chinese phone after format ffs now phone dead.
I flash both firmware & eeprom backup file, but phone still same....
Solution please...
COM4 [VCP0] selected
module v3.09
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:6903:0000
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.09, database date: 19.02.2010):
V600CA_XZY_ADI_LANG_C_PCB01_GPRS_MT6225_S00.V600CA _XZY_ADI_LANG_C_V3_3_4.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: V600CA_XZY_ADI_LANG_C_PCB01_GPRS_MT6225_S00.V600CA _XZY_ADI_LANG_C_V3_3_4.BIN
project-id: V600CA_XZY_ADI_LANG_C_V3.3.4, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00E40000
Detected ffs/eeprom address is non-standard: 00E40000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E40000
detecting ffs/eeprom size...
ffs/eeprom size: 001C0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E40000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: V600CA_XZY_ADI_LANG_C_PCB01_GPRS_MT6225_S00.V600CA _XZY_ADI_LANG_C_V3_3_4__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\V600CA_XZY_ADI_LA NG_C_PCB01_GPRS_MT6225_S00.V600CA_XZY_ADI_LANG_C_V 3_3_4__ffs_20100310-161958.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 7 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to thushdt For This Useful Post:
Old 03-13-2010, 11:56   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
try to flash with this file:
flashfiles/ChineseMiracle/_MT6225/V600CA_XZY_ADI_LANG_C_PCB01_GPRS_MT6225_S00.V600CA _XZY_ADI_LANG_C_V3_3_0_16m_En_Fr_Es_It_Pt.B0M.bin
chaina phone dead after format by using infinity Box MANfaith Chinese Models & Cloned Phones 9 09-06-2009 08:38
bluetooth china phone dead after formating Gordak_air Chinese Models & Cloned Phones 2 11-27-2008 08:19
phone dead after format jbbasha Infinity-Box 3 10-15-2008 17:01
china n92 dual sim phone dead after format /ARIF/ Infinity-Box 10 03-26-2008 11:39
china n92 dualsim phone dead after format with infinity /ARIF/ Chinese Models & Cloned Phones 1 03-22-2008 01:24
Page generated in 0.16107 seconds with 9 queries
