Old 02-08-2009, 13:55   #1 (permalink)
neetika99's Avatar
Member: 588837
Thanks Meter: 142
kp199 lock code ...done
lg kp199 lock code readed with infinity sucessfully.here r logs
COM7 [VCP1] selected
module v2.53
Action: read codes
unlock method: read codes
Model: LG-KP199
Checking data, wait...
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
chip: 0031:A27A:EDBB
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: 7S7339IN00-001-R1B
Version: EP2_HW
44 byte(s) read
imei: ##############
connection Ok
157 byte(s) read
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 11071991
Finished, time used: 14 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to neetika99 For This Useful Post:
Old 02-08-2009, 14:23   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
module v2.53
Action: read codes
Model: LG-KP199
19200 autodetect
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: EP2_HW
44 byte(s) read
connection Ok
157 byte(s) read
Phone lock: On
Network lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 07-18-2009, 10:06   #3 (permalink)
rgb1997's Avatar
Member: 110849
Thanks Meter: 23
what cable did you used?
Old 07-18-2009, 10:43   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,975
Cable name: KE500
keyboard top
1.........18
1: Gnd
2: Box Tx/Phone Rx (RJ45 pin-2)
3: Box Rx/Phone Tx (RJ45 pin-3)
5: Gnd
15: Gnd
18: Gnd
Old 07-18-2009, 16:12   #5 (permalink)
Member: 130995
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 09-18-2009, 12:34   #6 (permalink)
Member: 462076
Sonork: 100.1586314
Thanks Meter: 307
nice info boss
Old 02-23-2010, 18:30   #7 (permalink)
Member: 701004
Sonork: 1626436:danish
Thanks Meter: 113
Question
Originally Posted by PASSIONATE_BOYS View Post
Cable name: KE500
keyboard top
1.........18
1: Gnd
5: Gnd
15: Gnd
18: Gnd
Dear if use kg800 cable so that's work or not thx
Old 02-23-2010, 20:56   #8 (permalink)
Member: 1043909
Thanks Meter: 51,298
Hi,
You need to use KE500 cable but not KG800 cable.
Old 10-01-2010, 14:06   #9 (permalink)
Member: 867442
Sonork: 100.1602740
Thanks Meter: 143
[VCP2] selected
module v3.55
Action: reset settings ("format ffs")
Model: LG-KP199
19200 autodetect
CPU: MT6226
chip: 0031:F5DD:1F37
status: FF
Connecting at 19200, wait...
Date: 2005.04.12
Version: 1.0
Version: 7S7339IN00-001-R1C
Version: EP2_HW
44 byte(s) read
imei: 353***********
connection Ok
building list...
done
items to clear: 149
warning: wrong packet cs
items cleared: 139 of 149
items remains: 0
Finished, time used: 5 min 37 sec
i did safe mode but still hangs on kp199
Old 10-01-2010, 16:42   #10 (permalink)
Member: 130995
Try to make "format" in "complete" mode.
Make full flash backup before this operation.
k800i lock code done from semc newfoundghori free semc tool 10 07-30-2009 09:02
>>> MYPhone T22 DUO lock code done and PINOUT HERE <<< keaelite Infinity-Box 10 06-22-2009 20:22
MyPhone T22 Lock code done with infinity topnoyze Infinity-Box 1 11-20-2008 08:05
Alcatel S210 Lock Code Done By Infinity UnLoCkit Infinity-Box 1 08-29-2008 13:15
>>> N82 lock code done by infinity and pinout here <<< keaelite Infinity-Box 1 07-05-2008 12:26
Page generated in 0.52627 seconds with 8 queries
