05-11-2008, 22:38 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 476420 Status: Offline Sonork: 100.1605239 Thanks Meter: 164 | Kp200 Given Erurr In Flach advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: µµµµµµµµµµµµ current otp imei: 355590010139740 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35030526000000 1_LG KP200_20080511-233116.B1E.bin ............ version: utf-8,iso-8859-1,LG-KP200Obigo Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 01227E223C2200:FEEA0000000000 error: no any expected answer error: flash write error: 01080000:00040000 Write Fail Finished, time used: 273 sec Remove/Install battery now ! |
Alcatel S120 Flash File not found in support [SOLVED] | surin | PolarBox 3 | 16 | 03-30-2010 10:57 |
How to fix? - Given ServiceTag was not found in database | Denis | Cyclonebox | 1 | 01-19-2010 16:40 |
i900i dead in flache | qodsgsm | QUALCOMM Models (3G) | 5 | 10-18-2009 13:59 |
probleme in KP200 | nibalo | Infinity-Box | 3 | 10-01-2008 20:17 |
Has anyone suceeded in unlock lg kp200? | dsakun899 | ULT PRO | 0 | 02-19-2008 06:37 |
