12-26-2009, 10:41 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | kp220 only logo COM10 [VCP0] selected module v3.00 Device: LG-KP220 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031AA4:3769 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7338SA00-002-R1B.BIN project-id: 7S7338SA00-002-R1B, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: LG-KP220_ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7338SA0 0-002-R1B__ffs... file saved: C:\Program Files\InfinityBox\MModule\LG-KP220_ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7338SA0 0-002-R1B__ffs_20091226-140236.B0E.bin flash: 98004900000002:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:29EA0000000000 Finalization Done Finished, time used: 11 min 22 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! great infinity team |
The Following User Says Thank You to nadim electro For This Useful Post: |
12-26-2009, 11:30 | #2 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642536 Status: Offline Thanks Meter: 22 | re brother jus flash with these flash files KP220-00-V10c-ARB-XX-MAY-21-2008_ARIMA26_05C_PCB01_GPRS_MT6226M_S01[1].7S7338SA00-002-R1B_En_Ar_Farsi_Urdu_Ru_Fr.B0M and also with this eeprom ... KP220_ffs_01[1].B0E you can donwload these files from support area after that your problem will solve.. br. mobile_doc |
01-05-2010, 17:55 | #3 (permalink) | |
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | Quote:
01-05-2010, 20:06 | #4 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: TUNISIA Age: 43
Member: 367280 Status: Offline Thanks Meter: 57 | Quote:
phone are ok men all is well do you see the log or what | |
e700 show only logo samsung and die! | nykocam | UST Pro II | 2 | 03-31-2007 09:17 |
x820 i try flash now show mw only logo | MNGASHNET | NSPRO | 2 | 09-24-2006 09:11 |
nokia 3650 only logo | kiran | UFS2 + UFS3-Tornadoflasher | 6 | 09-02-2004 14:11 |
6600 stay only logo NOKIA | Velko | WD2 & APE (Symbian Phones) | 3 | 05-07-2004 20:30 |
