Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2000 Location: Burkina Faso , Bobo Dioulasso Age: 42
Member: 2920 Status: Offline Thanks: 25
| KP235 flash write error , now phone is dead Trying to flash gkp235 with LGA 1.36 & LGA 1.38 , flash stop when write 2nd chip area. Now phone is dead. Tried to use full flash from support area , flashing stop at the sme step. Phone was working I wanted to change langpack. ==== log: [23/03/2009 14:30:54] ==== COM19 [Serial2] selected module v1.36 Device: LG-KP235 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" active "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005258 Boot Done Set baud ... 230400 Set baud Done Check flash ... current eeprom imei: 352127021254888 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352127021254888_LG-KP235_20090323-143136.B1E.bin .... Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 Write: Alchemy data flash: 90089008910091:99989D00000000 flash: 90889088918891:99989900000000 flash: 89881600010001:89881600000000 write: 2nd chip area error: error# 000070F0 40:6[01]: Erase suspend in effect. 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 18000000:00010000 error: error# 000070F0 40:6[01]: Erase suspend in effect. 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 18000000:00010000 error: error# 000070F0 40:6[01]: Erase suspend in effect. 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 18000000:00010000 error: error# 000070F0 40:6[01]: Erase suspend in effect. 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 18000000:00010000 error: error# 000070F0 40:6[01]: Erase suspend in effect. 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 18000000:00010000 Write Fail Finished, time used: 1398 sec Remove/Install battery now ! With LGA 1.38 same problem ==== log: [23/03/2009 19:19:17] ==== COM19 [Serial2] selected module v1.38 Device: LG-KP235 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" active "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005258 Boot Done Set baud ... 230400 Set baud Done Check flash ... current eeprom imei: 352127021254888 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352127021254888_LG-KP235_20090323-191955.B1E.bin .... Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 Write: Alchemy data flash: 99889680978083:99889600000000 flash: 99889600970003:89889600000000 flash: 89881600010001:89881600000000 write: 2nd chip area error: error# 000060F0 40:6[01]: Erase suspend in effect. 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 18000000:00010000 Write Fail Finished, time used: 52 sec Remove/Install battery now ! Now phone display only KP235 logo and freeze. Any issue ? |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks: 814
| yes same to me set recieved for security code , but after factory reset network gone then try to flash with different fw but it always gives this type of error and now just stuck on kp235 logo !!! how to solve this problem ??????????????????????? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| write flash checksum OK....But phone is dead | amol_sm | Universalbox | 7 | 06-12-2009 22:22 |
| help...6280 error unlocking phone is dead now | lie_james | J.A.F. V-SPEC | 4 | 05-26-2008 02:44 |
| Error unlocking W810i...now phone is dead! | jontyjonty | MT-BOX | 6 | 11-21-2007 22:05 |
| Flashed T809 with 820 now phone is dead. | Shocker00 | Samsung Flashers, Software, Firmware. | 1 | 06-01-2006 05:37 |
| NSDongle crashed while flashing. Now phone is dead, and can't be flashed. | James_S | NSPRO | 6 | 02-19-2006 01:09 |
