Old 11-30-2007, 07:26   #1 (permalink)
webshawk's Avatar
Member: 107267
Thanks Meter: 62
TECNO T800 dead after flash
This is True i always done succuss work on chiness phone with INFINITY
but this time i flash TECNO T800 (File download from support) now phone is not startup (only side light blinking) i use rpl service but cant get any result
Pls. help me ... now what i do.....
Old 11-30-2007, 13:35   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please check log file for phone original version and try to fond similar on support.
post here what it was
Old 11-30-2007, 13:59   #3 (permalink)
webshawk's Avatar
Member: 107267
Thanks Meter: 62
This is LOG when i first time formate this phone
Do you want to continue ?
COM5 [VCP0] selected
Device: Tecno T800
Checking data, wait...
advanced flash detection active
Action: reset
Boot...
Connecting, wait...
Initializing[6225:8A03]...
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Identification...
detect device identification, method #1...
detection phase #1...
detect device parameters finished
structure: 2nd [standard] (or higher) generation
protocol ver: 04
ver. sw1: BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3.BIN
ver. sw2: CBM10_2_E_V3
ffs offset/size: 00E00000/00200000
reading [eeprom[BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3.BIN]]...
file saved: backup_eeprom[BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3.BIN]_20071127-211235.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
flash: 98004900000002:AD6CAD00000000
Write Done
Finished, time used: 233 sec
Remove/Install battery now !
Old 11-30-2007, 14:06   #4 (permalink)
Member: 148515
hello!
our flash file for this phone is for different hardware. you can see this by comparing version:
yours: BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3.BIN
support: CBM01_PCB01_GPRS_MT6226_S01.CBM04_070711_V60_En_Fr _Ar.B0M.bin
you can see that MCUs are different.
you must find good working phone with 6225 MCu and read out backup. we will update our suport area with needed file.
in future always carefuly check if flash file is suitable for you phone. If any doubts- make full backup of your existing firmware for emergency case.
Old 11-30-2007, 14:21   #5 (permalink)
webshawk's Avatar
Member: 107267
Thanks Meter: 62
thank you sir .. i try to get same model and same mcu and send as soon as posible.
I love my box for great support like this
Old 12-04-2007, 16:50   #6 (permalink)
webshawk's Avatar
Member: 107267
Thanks Meter: 62
hello sir. i have same (BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3.BIN ) phone, and i read full flash, Now what i do ? (give me mail address when i send this file)
Old 12-04-2007, 16:55   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
please, send "backup_flash..." files to [email protected]
also pls send "backup_system_log..." files, it's important
Old 12-06-2007, 08:44   #8 (permalink)
webshawk's Avatar
Member: 107267
Thanks Meter: 62
i send backup file and i get flash file from support area, Thank you INFINITY,
now i flash my phone but cant get any result.....i flash by same version file but phone cant start up only blink side lite...
what i do ???? Help me ...
Old 12-06-2007, 18:49   #9 (permalink)
Member: 130995
Hello,
Please, use Tecno-T800_BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3 _En_Fr_Ru_Ar file from support area and use latest ChineseMiracle.
Make "format" after flashing.
Post here flashing log.
Don't forget to charge batery complately !
Old 12-07-2007, 08:31   #10 (permalink)
webshawk's Avatar
Member: 107267
Thanks Meter: 62
Yes Sir, i use this file and format after flashing but cant get result,
but i have eprom backup of this phone (backup creat when i flash this phone first time)
this backup write on phone (after flash above file)and now my phone is ON and work fine ............
Thank you for your co-opration...
Old 07-10-2008, 08:44   #11 (permalink)
milankumardoshi's Avatar
Member: 135200
Sonork: 100.1594691
Thanks Meter: 33
please give me pinouts of tecno t800 12pin L12c cable
please give me pinouts of tecno t800 12pin L12c cable i cannot detect pins with any finder and aslo i used the pins near the sim reader but still cannot work.
The Following User Says Thank You to milankumardoshi For This Useful Post:
Old 07-10-2008, 11:53   #12 (permalink)
Member: 148515
hello!
t800 do not keep tx/rx in system connector- this is why pinfinder failed to find pinout.
please check infinity pinout folder for file named "Tecno-T800.jpg"
that will be correct pinout for your phone
Old 08-06-2008, 14:36   #13 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
i have pinout 1.30 version but i have not t800 pinouts
6300 dead after flash 6233 dead after flash mobileZONE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-27-2010 01:17
Dead 9210e Orange UK Dead after flashing :( PhantomGSM Trisha & Matrix Flasher 4 05-06-2009 12:02
Page generated in 0.27475 seconds with 9 queries
