11-15-2007, 00:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | KTECH 8030 cant format second sim !!! COM7 [VCP2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification, method #1... detection phase #1... . detection phase #2... ........... detect device parameters finished protocol ver: 02 ver. sw1: E550AGENT_E550_GSM_MT6205B_DN.01_4.BIN ver. sw2: E550AGENT.01.4 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error checking area[00000000]: 00000000-007FFFFF... eeprom found near: 00380000 Detected eeprom address is non-standard: 00380000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address[00700000] confirmed by user detecting eeprom size... eeprom size: 00100000 eeprom chip: 00 eeprom area: 00000000:00700000-007FFFFF reading [eeprom[E550AGENT_E550_GSM_MT6205B_DN.01_4.BIN]]... warning: wrong data size at 0x00705800, retry... warning: wrong data size at 0x00705800, retry... warning: wrong data size at 0x00705800, retry... warning: wrong data size at 0x00705800, retry... warning: wrong data size at 0x00705800, retry... warning: wrong data size at 0x00705800, retry... warning: wrong data size at 0x00705800, retry... warning: wrong data size at 0x00705800, retry... warning: wrong data size at 0x00705800, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request Identification Fail Finished, time used: 279 sec Remove/Install battery now ! |
11-15-2007, 00:08 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to read flash again and send to [email protected] Also please include in your mail all "cfi" files from "Chinese Miracle" folder. |
2 phones same problem -cant end cal on second sim | AKKA | Infinity-Box | 2 | 06-11-2008 15:27 |
why second sim not work after format ffs? | zone2 | Infinity-Box | 9 | 05-27-2008 08:56 |
ktech 8030 pinout her | ashok_kumar459 | Infinity-Box | 4 | 04-23-2008 12:39 |
format second CPU memory and restore IMEI | appolo | Infinity-Box | 3 | 04-15-2008 02:33 |
TV900 frist sim formated done but freeze after try to format sconed sim | Sudan-Mobiles | Infinity-Box | 3 | 02-21-2008 11:27 |
