04-22-2009, 05:18 | #1 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | ku 215 unlock ok... within seconds!!... module v1.36 Device: LG-KP215 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 20880EFFFFFFFF:20880E00000000 flash: ST Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 359955014256178 file saved: D:\Program Files\InfinityBox\LGA\eeprom_359955014256178_LG-KP215_20090421-211324.B1E.bin ..... Check flash Done Check space ... current eeprom imei: 359955014256178 ............................... finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 42 sec Remove/Install battery now ! |
The Following User Says Thank You to ZIYAAD STRYKER For This Useful Post: |
ku 380 unlocked for few seconds | delchoni | VygisToolbox | 0 | 03-10-2009 13:05 |
Another KU-990 Unlocked in 9 SECONDS | Bharat Dhingra | KULANKENDI Server | 0 | 12-04-2008 12:53 |
N -95 Unlocking Done Within 20 Second | akhtar416786 | MT-BOX | 0 | 09-01-2008 05:42 |
KU 970 Unlock OK !!! | alunecosu_hd | FuriousGold | 7 | 03-01-2008 22:46 |
LG KU 450 unlock ok ... | alunecosu_hd | Easy-Unlocker | 13 | 02-20-2008 20:09 |
