Old 04-04-2008, 09:56   #1 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
L 832 Hang problem
Hi to everybody ,
This is L832 model (on the Lable). this model working OK.
But after switching on the phone it work perfectely (I mean Keypad OK , Menu function OK , All set OK) but after 3 - 5 minute phone doesen't operate.
Any key of phone can't work.
For example - I start the music player. after one song end I try to select next song but i can't do that. Even music player is working fine.
What to do . . . . . . .
Old 04-04-2008, 09:57   #2 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Here is the phone info.
Action: read information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6223, E04
Hardware version: HUAQIN23_07A_PMJ_HW
Software version: K110_00B_V0.3.A"
Software date: 2000.00.00
Barcode: HA71115045801604 11
imei: 355262000168994
Finished, time used: 43 sec
Power off phone now !
Old 04-04-2008, 10:07   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
solution is ussual- start from making full backup
then formating phone: first- safe, after- complete
Old 04-04-2008, 18:30   #4 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
I try to format the phone but this error show
COM24 [VCP0] selected
Action: reset settings
19200 autodetect
Initializing[6223:8A04]...
CPU: MT6223
high speed boot enabled
chip: 0011723:000C
Connecting, wait...
Release Power button now !
warning: can't read software version, probably unknown firmware
detecting structure #2...
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs
19 20 21 22 23 24 25error: detection failed (26 tries), read flash and send to support
connection lost
error: operation failed !
Finished, time used: 7 sec
Remove/Install battery now !
What to do............... ? ? ?
Old 04-04-2008, 18:33   #5 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
And also some time this error show
19200 autodetect
CPU: MT6223
chip: 0011723:000C
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
Finished, time used: 115 sec
Old 04-04-2008, 18:39   #6 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
And here is the detail information of phone.
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011723:000C
boot step size: 0400
Boot Done
Initialize...
flash: EC257E25062501:2AEA0000000000
flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: K110B_PCB01_GPRS_MT6223P_S00.K110_00B_V0_3_A.BIN
ver. sw2: K110_00B_V0.3.A, 00000000
ffs offset/size: 00700000/00100000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00700000
checking area[00000000]: 00000000-007FFFFF...
eeprom/ffs found near: 00700000
detecting eeprom/ffs size...
eeprom/ffs size: 00100000
ffs chip: 00
eeprom/ffs area: 00000000:00700000-007FFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Finished, time used: 39 sec
Old 04-04-2008, 18:42   #7 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
And also can't formate this phone
Where is the problem . . . ?
What's wrong with me . . . . . . ?
Here is the last log.
19200 autodetect
CPU: MT6223
chip: 0011723:000C
Connecting, wait...
Finished, time used: 58 sec
Old 04-05-2008, 10:38   #8 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
What to do for this problem . . . ?
Infinity team........ Where r u .........?
Old 04-05-2008, 17:46   #9 (permalink)
Member: 130995
Thanks Meter: 35,227
Why you did not read FAQ before post here strange logs ?
Too busy to read but not so busy to write ?
http:///vbb/showthread.php?t=447277
Old 04-06-2008, 06:23   #10 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Thank You for the replying
I read out complete FAQ many time's
but ............. in this step . . . . .
19200 autodetect
CPU: MT6223
chip: 0011723:000C
Connecting, wait...
When i long time press power button phone is switched on.
and after on the phone this error show . . .
19200 autodetect
CPU: MT6223
chip: 0011723:000C
Connecting, wait...
That's why i post here all type of log.
Old 04-06-2008, 20:03   #11 (permalink)
Member: 148515
hello!
if both methods (safe & complete) of formating is not working for you-
probably you must turn to hardware check.
kg195 hanging problem logo hang rameez_gsm Infinity-Box 7 01-22-2009 14:41
nokia n73 blue lcd problem & hang problem ahmad mobiles Nokia Hardware & Hardware Repair 0 10-28-2008 09:52
sendo s200 hanging problem gsmsaver Various 1 03-13-2002 02:55
lets share our info about 33XX hang problems . makona Nokia Hardware & Hardware Repair 17 10-14-2001 16:31
nokia 3310 ...1) hanging problem 2) contact service PTR999 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-08-2001 11:04
Page generated in 0.25477 seconds with 9 queries
