11-23-2008, 12:31 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Uk/Pk
Member: 436045 Status: Offline Sonork: 1581208 Thanks Meter: 31 | L12B Cable Doesnt work :( i m using infinity pinfinder 2 in one cable L12B+L8A.. I checked L12B on several fones but it doesnt find any pins. Can u plz help me with its diagram? i opend up tha cable and all wires soldered well but still no response.. Plz helPpp.. Br. TOm @ Future Fones |
11-23-2008, 14:22 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! every cable pinout is given at the end of Pinfinder user manual. just take multimeter, set it to resistance measuring and check if all pins in L12b connected to correspondent pins in DB26 |
11-27-2008, 11:02 | #3 (permalink) |
Member: 436045 Status: Offline Sonork: 1581208 Thanks Meter: 31 | hi there I checked them on multimeter all pins showing connectivity but still cable is unable to detect any pins at all. What i feel is there's a problem with wire combinations.. would u be kind enough to help me with it? post me a diagram of working cable so that i see if there's any problem with combination or something else.. Thanks in advance WBr, |
11-27-2008, 20:15 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! open pinfinder manual, in my edition this is page 35. find there connector L12B picture. there you will see how is numerated connector pins. Check with multimeter where goes pin1 (resistance measuring mode). here is how to use multimeter for this operation: http://forum.gsmhosting.com/vbb/show...11&postcount=5 one multimeter probe set to pin1, with another probe touch another cable side pin1 of connector DB26. you should see connection. same way check pins 2,3,4,5...12 all of them should have connection with correspondent pin in DB26. DB26 connector pins a numerated with small digits, just look inside carefuly |
easy cable doesnt work for dct4 plus? | GsmTracer | Genie Universal | 3 | 12-12-2008 17:06 |
W850 flashed on some different model n now doesnt work... :( | The SAINT® | WotanServer | 1 | 02-26-2007 16:08 |
GX15 cable not working :( | .::GT-GSM MAN::. | Sharp | 0 | 02-22-2006 10:42 |
Nk 1100 flashlight doesnt working :( | selfone69 | Nokia Hardware & Hardware Repair | 0 | 04-02-2005 03:28 |
