04-07-2009, 13:18 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 599037 Status: Offline Thanks Meter: 103 | l343i flashed but still dead..plz hlp COM22 [VCP1] selected module v1.36 Device: LG-L343i Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 error: wrong answer: 3B flash: 01227E223C2200:FEEA0000000000 flash: Amd PL256N D 16Mb id: 0000527A Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 351700011538063 current otp imei: 351700012767117 file saved: C:\Program Files\InfinityBox\LGA\eeprom_351700011538063_LG-L343i_20090407-160602.B1E.bin .. Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 01227E223C2200:FEEA0000000000 Write: Eeprom flash: 01227E223C2200:FEEA0000000000 Write Done Finished, time used: 76 sec Remove/Install battery now ! what shud i do now??? |
04-07-2009, 19:26 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | What to do: 1. do not post repeated messages. As you can see Infinity-Box supporters make an answers in this forum so fast as possible. Thread with repeated posts will be answered LATER than ordinary posts. 2. explain what was the problem with phone before flash process |
04-08-2009, 12:05 | #4 (permalink) | |
Member: 599037 Status: Offline Thanks Meter: 103 | Quote:
hmmm i got the fone in the dead condition with an empty battery.. i used the xternal pwr supply and flashed the fone but still in same condition.... | |
04-08-2009, 17:43 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If after flashing phone can not power on at all you have a reason to open phone and check it's hardware. |
w700.. flash ok but still dead... plz help urgently | vinkle | Sony Ericsson Hardware Repair | 9 | 12-28-2008 06:50 |
nokia 6600 dead taking flashing,but still dead | sandeepmtc | Nokia Hardware & Hardware Repair | 0 | 08-24-2007 17:53 |
Dead Dct 4 phones ,flashes but still dead | eko | Nokia Hardware & Hardware Repair | 6 | 04-29-2004 22:47 |
c45 ba20 flashed but still dead | robba | x1x to x45/x50 | 4 | 07-29-2003 16:48 |
