Old 10-14-2008, 21:30   #1 (permalink)
Registered User
eko_java_cell's Avatar
Member: 347872
Thanks Meter: 5
i-mobile ceo889 dead after flash
hi...infinity team i have a problem with this phone before restart problem,i try to format complite but still restart,i try to flash but any accident low batree i flash again phone became dead now.i download file from support only one choise.can u give me solution???
this log flash
COM3 [VCP0] selected
Device: I-Mobile CE0889
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:4FC1:5906
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S00.7S-7311-THS0-0.BIN
ver. sw2: 7S-7311-THS0-0, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S00.7S-7311-THS0-0.BIN]]...
file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S00.7S-7311-THS0-0.BIN]_20040101-144632.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Area: Firmware
Write: Firmware
Write Done
Finalization...
formatting...
flash: 98004900000002:61633600000000
Finalization Done
Finished, time used: 516 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Nb.I hold power button but still dead
Old 10-14-2008, 23:14   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what was your phone original version?
Open operatio.log file which is located in Chinese Miracle folder.
find firswt operation with this phone and post this log here
Old 10-14-2008, 23:21   #3 (permalink)
Registered User
Member: 347872
Thanks Meter: 5
hello!
this first backup eprom i find at M modul :
backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-INS0-0-R1B-3.BIN]_20081009-232820.B0E
In support only one flash file for ceo889,whats different 510 and ceo889???
Old 10-15-2008, 00:43   #4 (permalink)
Member: 148515
hello!
what result do you get with this flash file?
flashfiles/IMobile/CE0889/IMobile-CE0889_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-INS0-0-R1B-3__En_Ml_Id_Th_Cn.B0M.bin
Old 10-16-2008, 22:08   #5 (permalink)
Registered User
Member: 347872
Thanks Meter: 5
hello!
its the first i do flashing with this file n the result phone can power on.
Any sugestion for my sir??
thanks before
Old 10-17-2008, 17:19   #6 (permalink)
Member: 148515
thanks before
"can" or "cant" ? i dont get this
Old 10-17-2008, 21:59   #7 (permalink)
Registered User
Member: 347872
Thanks Meter: 5
sory for my thread i mean can't (dead)
Old 10-18-2008, 04:27   #8 (permalink)
twentyonecell's Avatar
Member: 664744
Thanks Meter: 156
this log flash
"format ffs" active
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
Boot Done
Initialize...
Initialize Done
Set baud...
460800
Set baud Done
Write...
Area: Firmware
Write: Firmware
Write Done
Finalization...
formatting...
Finalization Done
flash with fimware imobile510....imobile510 and imobile C0889 is same
Old 10-18-2008, 15:34   #9 (permalink)
Member: 148515
hello!
try format FFS complete if phone do not start after flashing.
if still no positive result- must be used another flash file for flashing
can you find similar working phone on local market?
Old 10-21-2008, 20:55   #10 (permalink)
Registered User
Member: 347872
Thanks Meter: 5
Bos twenty i try flash with firmware 510 u upload at FIF but same problem,Maybe damege epprom ???
Do U have epprom backup from 510 normal phone???can u upload in here???
6300 dead after flash 6233 dead after flash mobileZONE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-27-2010 01:17
lcatel e221 dead after flash first virgin mobile software shakeel145 Infinity-Box 4 02-22-2010 16:16
3110 C Most mobiles getting dead after flashing phone2world Nokia Base Band 5 ( BB-5 ) 10 08-19-2009 08:15
plez help i-mobile 306 Set dead after Flash SHOEB AHMED Infinity-Box 4 08-14-2008 07:12
Page generated in 0.23941 seconds with 9 queries
