10-20-2016, 15:55 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Lanix Iluim L900 QCOM 8916 All Operations Done Read Flash Read Pattern Logs.. Code: Operation : Identify [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device Found! Initialize ... Card found : S/N : CDF48C7B , v0134 Infinity-Box Qualcomm Module [QLM] v 1.00 Operation : Identify [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 00EB7AEF ID_BLOCK_I : 007050E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , VER : 1 ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : LANIX ProdName : Ilium_L900 ProdModel : ILIUM L900 Device : Ilium_L900 AndroidVer: 4.4.4 Manufact. : LANIX QLMxCPU : MSM8916 Done! Elapsed: 00:00:32 Reconnect Power/Cable! Operation : Read Flash [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 00EB7AEF ID_BLOCK_I : 007050E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , VER : 1 ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : LANIX ProdName : Ilium_L900 ProdModel : ILIUM L900 Device : Ilium_L900 AndroidVer: 4.4.4 Manufact. : LANIX QLMxCPU : MSM8916 DevInfo : MSM8916__LANIX__LANIX__ANDR_v4.4.4__ILIUM_L900__Ilium_L900__Ilium_L900 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : splash.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : oem.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 1843 MiB Done! Elapsed: 00:05:35 Reconnect Power/Cable! Operation : Read PatternLock [ v1.00 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require make TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 00EB7AEF ID_BLOCK_I : 007050E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , VER : 1 ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 15487 Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
