09-23-2008, 08:23 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Here is a link: http://www.infinity-box.biz/index.php?id=support What is the problem with Vista ? We have tested it with Vista and it was no problems detected. |
09-23-2008, 08:44 | #5 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: inside smart
Member: 175216 Status: Offline Thanks Meter: 53 | Quote:
here screenshot! | |
09-23-2008, 08:49 | #7 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Brother i think u r using WORLD CALL for INTERNET. Then PM me i will give u a great solution. If not using then simply reinstall WINDOWS and also SHELL. |
10-17-2008, 19:35 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Latest Shell was double tested under Vista and no problems was found. I am interested in more details: when you see the error ? what button you press before you see an error ? |
10-18-2008, 19:30 | #11 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | Quote:
and also than i cant close the shell,the only way to close the shell is to go task manager and than click End the task. | |
10-18-2008, 22:40 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to make this: 1. open this file in Wordpad or Notepad: C:\Program Files\InfinityBox\shell\shell.ini 2. change two lines like in my example below: AutoUpdate=0 AutoNews=0 3. save file and try to run Shell again What is the results ? |
11-13-2008, 18:53 | #13 (permalink) |
Junior Member Join Date: Sep 2006
Member: 352496 Status: Offline Thanks Meter: 0 | access vilation right after open the program as soon you open the shell 1.24 in vista you get the error, if I edit the shell.ini it open and works, but if you hit the check for infinity box update the error comes back. any solution? |
11-21-2008, 13:57 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Shell v1.26 released. It was trested by several users and it was no problems found with Vista. Please, try to use Shell v1.26 and report about results. |
Last version of Qualcomm v1.0.0.20 is not worlking... | Angelo Cruz | FuriousGold | 0 | 12-06-2007 01:54 |
what is the last Version of 6120C from nokia | Fast Unlocker | Nokia Base Band 5 ( BB-5 ) | 6 | 09-29-2007 09:09 |
is there something i should do to install the last version of N95?????? | tsarkh | HWK | 0 | 06-05-2007 21:54 |
Looking for last RM-49 EMEA firmware and what version of phoenix is needed... | jackhk | Nokia Base Band 5 ( BB-5 ) | 5 | 10-09-2006 23:10 |
last version of Dark Flasher Shell | Dark Lemming | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 36 | 07-30-2001 18:27 |
