Old 10-22-2014, 15:53   #1 (permalink)
Member: 702572
Sonork: 9837200009
Thanks Meter: 73
Lava 355 error
Card found: S/N 085E:0128
Chinese Miracle II [MTK module] v 1.04
Operation : Check / Read Info [ v1.04 ]
Wait for phone...
Phone found! [ 42 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
BB_CPU_NM : [MediaTek] MT6575_S00
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Stat : v3.2 on BBID : 0x84
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0068 , [ST] ST512R4A
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Initial info read Ok!
Done!
Elapsed: 00:00:06
Reconnect Power/Cable!
Operation : Read Flash [ v1.04 ]
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
NAND settings not exists, will check now ...
Settings read Ok!
- > Re-connect battery and start operation again!
Done!
Elapsed: 00:00:13
The Following User Says Thank You to amancommunicati For This Useful Post:
Old 10-22-2014, 15:55   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
And where is error?
By the way - not need format 6575 NAND now.
Old 10-22-2014, 15:55   #3 (permalink)
Member: 702572
Sonork: 9837200009
Thanks Meter: 73
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:06
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Settings read Ok!
Done!
Elapsed: 00:00:13
Wait for phone...
Phone found! [ 12 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
EXT RAM : 0x00000000
SOC VERIFY : C1
Boot Ok!
USBDL : Error init HSUSB!!!
Operation Failed
Elapsed: 00:00:24
Wait for phone...
Phone found! [ 55 ]
Sync...
Brom Init not done
Boot Error!
Operation Failed
Elapsed: 00:00:05
Operation : Format FileSystem [ v1.04 ]
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Format : Cache and UserData (Full Factory Reset)
Format CACHE block
Format block Ok!
Format UDA block
Set HW_STORAGE failed! Something wrong with HW?
Operation Failed
Elapsed: 00:00:19
Page generated in 0.22643 seconds with 7 queries
