Old 06-15-2016, 12:17   #1 (permalink)
Member: 411636
Thanks Meter: 7
Lava a67 frp lock
HELLO SIR,
I received this set for frp unlock, so how to do with CM2
Here is log
Card found: S/N : 02464F3F , v0130
Chinese Miracle II [SPD module] v 1.19
Loading : LAVA_A67_S112_20160516.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : LAVA_A67_S112_20160516
FastCheck : 0x00618B98A2
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : SC7702_pike_modem.bin
File : DSP_DM_G2.bin
File : SC8800G_pike_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : oem.img
File : persist.img
File : sysinfo.img
File : userdata.img
File : LOGO.bmp
File : LOGO.bmp
File : cache.img
File : u-boot.bin
File : SC7730_UMS.xml
Load Ok!
Operation : Check/Read Info [ v1.19 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 16 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
PickUp loaders from pac
Boot failed!
Boot failed!
Reconnect Power/Cable!
Thanks
Old 06-15-2016, 12:23   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,212
Hello.
Seems as FW, which you have selected not work with that HW.
Select SC7731 eMMC A5 in settings and try make Format FS.
If no luck - tick "ALTLDR" option and repeat Format FS.
The Following User Says Thank You to JayDi For This Useful Post:
Old 06-24-2016, 15:39   #3 (permalink)
RICKY great's Avatar
Member: 641849
Sonork: 100.1619689
Thanks Meter: 44
Originally Posted by JayDi View Post
Hello.
yes it worked with reset via svc but frp still same no change in frp
Old 07-06-2016, 08:06   #4 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,603
Originally Posted by taturi View Post
hello sir,
i received this set for frp unlock, so how to do with cm2
here is log
card found: S/n : 02464f3f , v0130
chinese miracle ii [spd module] v 1.19
loading : Lava_a67_s112_20160516.pac
crversion : Bp_r1.0.0
paccpuinfo : Sc77xx
pacversion : Lava_a67_s112_20160516
fastcheck : 0x00618b98a2
loading files ...
File : Fdl1.bin
file : Fdl2.bin
file : Nvitem.bin
file : Nvitem_wcn.bin
file : Prodnv.img
file : U-boot-spl-16k.bin
file : Sc7702_pike_modem.bin
file : Dsp_dm_g2.bin
file : Sc8800g_pike_wcn_dts_modem.bin
file : Boot.img
file : Recovery.img
file : System.img
file : Oem.img
file : Persist.img
file : Sysinfo.img
file : Userdata.img
file : Logo.bmp
file : Logo.bmp
file : Cache.img
file : U-boot.bin
file : Sc7730_ums.xml
load ok!
Operation : Check/read info [ v1.19 ]
2. Press and hold 'volumeup' and 'volumedown' keys
3. Insert cable
==== wait for phone...
Phone found! [ 16 ]
port opened
sync...
Initboot done [ 0x81 ] , ver : Sprd3
sync...
Sending fdl
[info] : If sw freeze here more, than 15 seconds - remove cable
pickup loaders from pac
boot failed!
Boot failed!
Reconnect power/cable!
Thanks
hi,
flash with new ver file, frp unlock done by many time tested
Old 07-06-2016, 08:11   #5 (permalink)
Member: 641849
Sonork: 100.1619689
Thanks Meter: 44
Originally Posted by sunilkumar70791 View Post
hi,
can u share a link for that file
Old 09-19-2016, 12:21   #6 (permalink)
prakashmborana's Avatar
Member: 600436
Thanks Meter: 218
Lava a67 frp solve
HELLO BRO
LAVA A67 SPD CPU SC7735
MIRACLE BOX CM TOOL CS TOOL INFERONO DONGLE& OTHER DEVICE
NOT ACTIVATE
VERY SEMPLE SOLUTION
NOW FLASH
Lava A67 s113
Lava A67 s112
NOORA BHAY KGNMOBILE SERVICE CENTER MANGOAN RAIGAD MAHARASHTRA
The Following User Says Thank You to prakashmborana For This Useful Post:
Old 10-25-2016, 14:32   #7 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,263
lava A67 Frp done
Phone found! [ 54 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:17
Page generated in 0.27145 seconds with 7 queries
