Old 08-29-2015, 09:49   #1 (permalink)
Registered User
Member: 726546
Sonork: 100.1578784
Thanks Meter: 555
q mobile a-300 unable to read factory file format and read patern
unable to format read patern and read factory file plz check this bug here is the logs
Operation : Read Flash [ v1.26 ]
Wait for phone...
Phone found! [ 224 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00AD00BC00900055005600AD00BC0000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0094 , [Acsip] A5R4GA41ATS
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Not supported FlashType for this operation yet
Done!
Elapsed: 00:00:11
Reconnect Power/Cable!
Old 08-29-2015, 10:06   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
For read pattern you need make "Read Info first".
Page generated in 0.12345 seconds with 9 queries
