07-31-2015, 06:40 | #1 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: india Age: 39
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | lava flair p1 password lock spd7715 lava flair p1 spd 7715 cpu how to remove Quote:
09-02-2015, 09:00 | #6 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Punjab
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | SPD 7715 format/reset option is enable but format not done... i have phone in hand with restart problem Last edited by darmobiles; 09-02-2015 at 09:05. |
09-02-2015, 09:21 | #7 (permalink) |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Phone found! [ 51 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! |
09-02-2015, 10:58 | #9 (permalink) |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | any solution please? i have other working phone, actually problem was, i mistakenly wipe data on fastboot on other tool and phone gets restart on logo |
09-02-2015, 12:14 | #13 (permalink) |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | You Are Great :) Infinity is best. Realy you save the phone's life also save me i don,t see this option in tension Thanks you so much VIJAY2U2........ also Thanks to infinity team Phone found! [ 347 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount part failed! Will use Forced Mode! Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! |
09-02-2015, 12:19 | #15 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | JayDi already tell U to do that but Ur R ignore him.Next time follow his instructions all be be ok Happy to see Ur problem solved Sent from my Lenovo A6000 using Tapatalk |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
