05-19-2016, 17:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Lava flair z1 pattern lock not done with cm2:- Code: Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : zsw898_lava Model Brand : LAVA Model Device: zsw898 AndrVersion : 5.0 BaseBand CPU: ZSW898 CompileDate : 14-Jul-15 5:43:57 AM Project Ver : Lava_Z1_S806L Model Ext : Flair Z1 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:16 Reconnect Power/Cable! Code: Operation : Read PatternLock [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! FlashMode Set : Ok! Reading PatternLock ... [Info] : UserData is big! Result can be empty! PatternLock Not Set! Elapsed: 00:00:16 Reconnect Power/Cable! BUT CUSTOMER NEEDS ITS PIC AND PHONE BOOK Code: Operation : Format File System / Reset Settings [ v1.18 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001688FC000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:19 Reconnect Power/Cable! WBR sahil2000ind |
06-25-2017, 14:59 | #4 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2614987 Status: Offline Thanks Meter: 5 | Lava flair z1 stuck on logo I format my password locked lava z1 via recovery mode,it shows an error like (failed to mount emmc),after format it stuck on logo i flashed it with working file,but still it stucks on logo please give some solution |
08-16-2018, 10:43 | #5 (permalink) | |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | can u explain which cm2 boot you use Quote:
which boot did u select | |
