05-08-2016, 17:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Lava iris 400q after app manager scan hangs on logo:- READ INFO Code: Operation : Check/Read Info [ v1.17 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC8830 Loader eMMC v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : 400Q Model Brand : iris Model Device: iris400Q AndrVersion : 4.4.2 BaseBand CPU: SP7730EC CompileDate : 01-Aug-14 7:31:24 AM Project Ver : KOT49H test-keys Model Ext : iris400Q ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:16 Reconnect Power/Cable! Code: Chinese Miracle II [SPD module] v 1.17 Operation : Scan APP's [ v1.17 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC8830 Loader eMMC v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Mount : /system Size : 0x0000000035A4E000 State : 0x0001 Model Name : 400Q Model Brand : iris Model Device: iris400Q AndrVersion : 4.4.2 Restore Backup now ... Restore done! PostFix : Clear UserData Ok! Elapsed: 00:00:37 Reconnect Power/Cable! NOW PHONE HANGS ON LOGO AGAIN I DID READ INFO BUT FULL INFO PHONE NOT READING READ INFO Code: Operation : Check/Read Info [ v1.17 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC8830 Loader eMMC v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:16 Reconnect Power/Cable! Code: Operation : Format File System / Reset Settings [ v1.17 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC8830 Loader eMMC v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000059FFB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:20 Reconnect Power/Cable! PHONE HAVE 08 SW VERSION BUT ON NET I ONLY FIND S09 AND S11. CAN IT BE FLASH WITH THESE VERION. WBR sahil2000ind |
05-08-2016, 17:57 | #2 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | PHONE SUCCESSFULLY REVIVED BY FLASHING S11 VERSION. READ INFO LOGS AFTER FLASHING Code: Operation : Check/Read Info [ v1.17 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC8830 Loader eMMC v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : 400Q Model Brand : iris Model Device: iris400Q AndrVersion : 4.4.2 BaseBand CPU: SP7730EC CompileDate : 11-Feb-15 2:34:47 AM Project Ver : KOT49H test-keys Model Ext : iris400Q ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:16 Reconnect Power/Cable! sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
