Old 08-31-2015, 14:44   #1 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,895
Lava iris done with cm2 1.27:-
READ INFO
Chinese Miracle II  [MTK module] v 1.27
Operation : Check / Read Info [ v1.27 ]
Wait for phone...
Phone found! [ 21 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 150100523832314D420079A3D880524F
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BM128
[eMMC] : FLASH_CID : 150100523832314D420079A3D880524F
[eMMC] : FLASH_LEN : 0x00000003A3E00000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : iris
ProdName  : IX9
ProdModel : X9
Device    : lava82w_grand_i
AndroidVer: 5.0
MTKxCPU   : MT6582
MTKxPRJ   : ALPS.L0.MP2.V1_LAVA6582.W.L_P17
MODEM :
BaseBand  : MT6582_S00_MOLY_WR8_W1449_MD_WG_MP_V1_1_wg_n
EXTRA :
LCD [0] : nt35590_hd720_dsi_cmd_auo
LCD Res : 1280x720
TOUCH [0] : GT9XX
CAM [0] : STOM_HAL_IMGSENSOR
CAM [1] : =s5k3h7y_darling_mipi_raw
CAM [2] : s5k3h7y_qtech_mipi_raw
CAM [3] : ov5648_darling_mipi_raw
CAM [4] : ov5648_qtech_mipi_raw
CAM [5] : ov5648_hds_mipi_raw
MODEM : lava82_l_grand_hspa
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
FORMAT
Operation : Format FileSystem [ v1.27 ]
Wait for phone...
Phone found! [ 21 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Backup : Skipped by user request
FMT Mode set to : 0
Format : Cache and UserData (Full Factory Reset)
Format CACHE block
Format block Ok!
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:38
WBR
sahil2000ind
The Following User Says Thank You to sahil2000ind For This Useful Post:
Old 08-31-2015, 15:06   #2 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 423
please post this successful post in sticky thread.
Old 08-31-2015, 17:38   #3 (permalink)
maomatrix's Avatar
Member: 901711
Sonork: 100.1606138
Thanks Meter: 423
but.. MT6582 emmc it's support many time ago.....
I post Lenovo S850 full support and read factory firmware whit old version of CM2...
Maybe 6595 or others is supported in new version....
Old 08-31-2015, 18:06   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,662
In some new versions changed not just "something", there is dozen of changes, which affect ALL platforms, starting from MT6575 and up to 6795/8127/83xx/87xx CPU's.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.24675 seconds with 7 queries
