12-21-2010, 11:27 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 666540 Status: Offline Thanks Meter: 354 | LAVA KKT25 new version flash file here http://rapidshare.com/files/43851457...0101221-144240. pinout......Rx=3 Tx=4 |
12-29-2010, 09:33 | #5 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | USER CODE ISSUE lavakkt25 after farmating ,,,unable to do factory reset asking input password.. itried 1100,1122,0000 1234 no luck LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T2 2G0114_M571__firmware_part_1_of_1_20101229-131540.B0M assit plzz |
The Following User Says Thank You to syed.n For This Useful Post: |
12-29-2010, 15:43 | #6 (permalink) | |
Member: 666540 Status: Offline Thanks Meter: 354 | Quote:
The Following User Says Thank You to rajeshlehal For This Useful Post: |
12-31-2010, 17:53 | #9 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | COM29 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E703:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 23.12.2010): LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T2 2G0114_M571.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T2 2G0114_M571.BIN project-id: LBBQK01.8.5.1.4T22G0114_M571, 00000000 code offset: 00000000 ffs offset/size [01]: 00D40000/002C0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00D40000 standard ffs/eeprom offset confirmed: 00D40000 detecting ffs/eeprom size... ffs/eeprom size: 002C0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00D40000-00FFFFFF firmware area: 00000000-00D3FFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ............................... ffs/eeprom: detect std location pass #1... .................................................. ... ffs/eeprom: detect ext location pass #1... .................................................. . ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T2 2G0114_M571__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\LCSH25_08B_PCB01_ GPRS_MT6225_S00.LBBQK01_8_5_1_4T22G0114_M571__ffs_ 20101231-221015.B0E.bin flash: 01227E22202200:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E22202200:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 4 min 42 sec Remove/Install battery now ! COM29 [VCP0] selected module v3.25 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E703:0009 status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 18 sec Remove/Install battery now ! COM29 [VCP0] selected module v3.25 Action: "user code" unlock method: smart fast Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E703:0009 status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 17 sec Remove/Install battery now ! COM29 [VCP0] selected module v3.25 Action: "sp-unlock" unlock method: smart fast Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E703:0009 status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 17 sec Remove/Install battery now ! ffs complete mode COM29 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E703:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 23.12.2010): LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T2 2G0114_M571.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: LCSH25_08B_PCB01_GPRS_MT6225_S00.LBBQK01_8_5_1_4T2 2G0114_M571.BIN project-id: LBBQK01.8.5.1.4T22G0114_M571, 00000000 code offset: 00000000 ffs offset/size [01]: 00D40000/002C0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00D40000 standard ffs/eeprom offset confirmed: 00D40000 detecting ffs/eeprom size... ffs/eeprom size: 002C0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00D40000-00FFFFFF firmware area: 00000000-00D3FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22202200:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:2AEA0000000000 Finalization Done Finished, time used: 53 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! no luck unable to do factory reset asking input password.. itried 1100,1122,0000 1234 regards! |
01-14-2011, 20:01 | #12 (permalink) |
Member: 432679 Status: Offline Thanks Meter: 118 | no use still same factory reset code problem used latest 3.26v 1 flashed latest file bothe from support 2 did complete erase then flashed again 3 tried all unlocked method their is only one cpu inside MT6225A 0949-BGDL CTG2H049 regards! |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
