05-28-2016, 06:43 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Lava X11 Frp Lock It's have SC9830 A7 CPU In Cm2 Hang When Try To Check or Format Also Spd Research Downloader Tool Says File Size is small or destructed Plz help me |
05-28-2016, 14:01 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | @VIJAY2U2 Hello, Post logs. Tried to flash with CM2? This phones uses customized spd flasher. BTW X11 original flasher name is- HQ_SPRD_UPGRADEDOWNLOAD_R3.0.0001_151222. Br. Infinity Box Support Team. |
05-28-2016, 15:55 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | A7 or A99999999 make nothing. There is 2 options ( normal and altldr ) if they not boot phone - probably, it have DRAM or eMMC changes , which are not affected in current loaders. Nothing more. |
05-30-2016, 06:31 | #9 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Yes Sir I try both way but cm2 always hang Code: Operation : Format File System / Reset Settings [ v1.18 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 28 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! |
08-29-2016, 19:35 | #12 (permalink) |
Junior Member Join Date: May 2009 Location: SAHARANPUR (U.P WEST)
Member: 1026439 Status: Offline Sonork: mukesh Thanks Meter: 5 | Go to fast boot mode volume +& power after show menu select bootloader option & contact miracle box fast boot platform & click micromax yuphoria frp lock 100% success Thanks miracle teem |
08-30-2016, 08:15 | #13 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Any next advertisement about other box/device/dongle in this section will be a big loss for you. Beware before posting, think and look where are you posting. Br. Infinity Box Support Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
08-30-2016, 12:28 | #15 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Lava X11 Frp Lock FRP done Code: Start at : [8/30/2016 / 4:43:45 PM] Operation : Check/Read Info [ v1.20 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 42 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : X11 Model Brand : Lava Model Device: X11 AndrVersion : 5.1 BaseBand CPU: X11 CompileDate : 3/2/2016 3:02:16 AM Project Ver : Lava_X11_S110_20160302 Model Ext : X11 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:33 Reconnect Power/Cable! Finish at : [8/30/2016 / 4:44:18 PM] Start at : [8/30/2016 / 4:44:22 PM] Operation : Format File System / Reset Settings [ v1.20 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 42 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001456F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! Finish at : [8/30/2016 / 4:44:47 PM] |
The Following 2 Users Say Thank You to sneha For This Useful Post: |
