11-20-2018, 11:55 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | LAVA Z50 Dead after flash dont know where wrong ! Code: Operation : Write Flash [ v2.02 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :13 [FL] : Set : preloader_lava6737m_op53.bin [FL] : Set : lk-sign.img [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : secro-sign.img [FL] : Set : tee-sign.img [FL] : Set : tee-sign.img [FL] : Set : odmdtbo-sign.img [FL] : Set : vendor-sign.img [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x4F4F90A8 [ 1.24 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM63) MODE : BOOTROM PORT : 63 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BOOTROM MODE : 0_base : BASE_v1836 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100464E36324D42033A5CA8BF2F7F DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 460001154D32364E5C3A03427F2FBFA8 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : MT6752 EMI : SRC : preloader_lava6737m_op53.bin EMI : CNT : 0003 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100464E58324D42 : VEN : SAMSUNG | DEV : FNX2MB : RAM : [ 1.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 90014A483847346132 : VEN : HYNIX | DEV : H8G4a2 : RAM : [ 1.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : PRELOADER_INFO [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E36324D42033A5CA8BFB47F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : DB612DF2F6059C6A44E2BDA62EE192DA STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_ID : 0x41414642393735303841323644334432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : TEE1 Write : TEE2 Write : ODMDTBO Write : VENDOR Write : SYSTEM Write : CACHE Write : USERDATA SEC_DL : True (CUST) SEC_ID : 0x41414642393735303841323644334432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:04:56 Reconnect Power/Cable! Code: Operation : Identify [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM48) MODE : PRELOADER PORT PORT : 48 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM63) MODE : BOOTROM PORT : 63 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BOOTROM MODE : 0_base : BASE_v1836 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100464E36324D42033A5CA8BF2F7F DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 460001154D32364E5C3A03427F2FBFA8 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : MT6752 EMI : SRC : preloader_lava6737m_op53.bin EMI : CNT : 0003 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100464E58324D42 : VEN : SAMSUNG | DEV : FNX2MB : RAM : [ 1.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 90014A483847346132 : VEN : HYNIX | DEV : H8G4a2 : RAM : [ 1.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : PRELOADER_INFO [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E36324D42033A5CA8BFB47F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : DB612DF2F6059C6A44E2BDA62EE192DA STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Boot done! Patch Level : O11019 Display ID : LAVA_Z50_1_8_V2.0_S140_20180605_ENG_IN Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-06-05 Build Time : 1528195156 Product Model : Z50 Product Brand : LAVA Product Name : Z50 Product Device : Z50 Product Manfct : LAVA Product Info : Z50 Board Platform : mt6737m USERDATA : ENCRYPTED Done! Elapsed: 00:00:18 |
11-20-2018, 12:08 | #2 (permalink) |
Freak Poster Join Date: Nov 2010 Location: CHOLOMAN
Member: 1440339 Status: Offline Sonork: 100.1616914;CHOLOMAN Thanks Meter: 116 | As a general user i can tell you next time after successful flashing, try fix tool dl image once. |
The Following User Says Thank You to .::JYOTIRMAY::. For This Useful Post: |
11-21-2018, 12:17 | #4 (permalink) |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | this is 2nd set this is 2nd set this time i tick on ADL checksum verify Code: Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02 Load IDBase v111571 Ok! Update configuration ... Update Ok! Load IDBase v111571 Ok! Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_lava6737m_op53.bin EMI : CNT : 0003 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100464E58324D42 : VEN : SAMSUNG | DEV : FNX2MB : RAM : [ 1.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 90014A483847346132 : VEN : HYNIX | DEV : H8G4a2 : RAM : [ 1.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] Operation : Write Flash [ v2.02 ] Repartition : Enabled Flash Verify : Enabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :13 [FL] : Set : preloader_lava6737m_op53.bin [FL] : Set : lk-sign.img [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : secro-sign.img [FL] : Set : tee-sign.img [FL] : Set : tee-sign.img [FL] : Set : odmdtbo-sign.img [FL] : Set : vendor-sign.img [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x4F4F90A8 [ 1.24 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM63) MODE : BOOTROM PORT : 63 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BOOTROM MODE : 0_base : BASE_v1836 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100464E36324D420340BA68060123 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 460001154D32364EBA40034223010668 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : MT6752 EMI : SRC : preloader_lava6737m_op53.bin EMI : CNT : 0003 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100464E58324D42 : VEN : SAMSUNG | DEV : FNX2MB : RAM : [ 1.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 90014A483847346132 : VEN : HYNIX | DEV : H8G4a2 : RAM : [ 1.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : PRELOADER_INFO [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E36324D420340BA6806B423 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3FD3CE80F68A49E61F3AA57AD03736F7 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_ID : 0x41414642393735303841323644334432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : TEE1 Write : TEE2 Write : ODMDTBO Write : VENDOR Write : SYSTEM Write : CACHE Write : USERDATA CHK : 0x00053100 : 0x7B53 : LK CHKSUM : FAIL : 0x0000000000002D8E : LK Error : Post-Flashing failed : Verification of region failed! Seems as some of MANDATORY section of FW is damaged! If device alive and work - send report! Reconnect Power/Cable! |
12-08-2018, 05:45 | #5 (permalink) |
Insane Poster Join Date: Jul 2015 Location: India,Gujrat,Surendranagar
Member: 2424934 Status: Offline Thanks Meter: 22 | same problem i got lava z50 with hangon logo after flash with Lava_Z50_MT6737M_20180605_8.1.0 phone gone in dead condition pleas help some wone |
12-08-2018, 06:03 | #6 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
will be fixed in next version | |
