06-06-2019, 17:27 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: Tamil_Nadu Rasipuram
Member: 2185083 Status: Offline Sonork: 100.1670782:dineshras Thanks Meter: 185 | Lava_A76_flasing_error - Unknown structure detected! Code: Card found: S/N : D0788583 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC983x] eMMC [Generic Android 6.x] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : A76 Model Brand : Lava Model Device: A76 AndrVersion : 5.1 BaseBand CPU: A76 CompileDate : 01-06-2016 04:28:27 Project Ver : Lava_A76_S113_20160601 Model Ext : A76 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:48 Reconnect Power/Cable! Operation : FlashIC ReadOnly/BadBlock Test [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:25 Reconnect Power/Cable! Loading : Lava_A76_S113_20160601.pac CRVersion : BP_R1.0.0 PacCPUinfo : PAC_SharkL5ModeMarlinAndroid5.1 PacVersion : Lava_A76_S113_20160601.pac FastCheck : 0x0059AF3EEE Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC9600_sharkl_5modcsfb_volte.bin File : LTE_DSP.bin File : SHARKL_DM_DSP.bin File : SC9600_sharkl_wphy_5mod_volte.bin File : PM_sharkl_arm7_dfs.bin File : fdl1.bin(1) File : EXEC_KERNEL_IMAGE0.bin File : boot.img File : recovery.img File : system.img File : oem.img File : persist.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : cache.img File : u-boot.bin File : SharkL5ModeMarlinAndroid5.1.xml Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : Lava_A76_S113_20160601.pac CRVersion : BP_R1.0.0 PacCPUinfo : PAC_SharkL5ModeMarlinAndroid5.1 PacVersion : Lava_A76_S113_20160601.pac File : fdl1.bin File : fdl2.bin File : nvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC9600_sharkl_5modcsfb_volte.bin File : LTE_DSP.bin File : SHARKL_DM_DSP.bin File : SC9600_sharkl_wphy_5mod_volte.bin File : PM_sharkl_arm7_dfs.bin File : fdl1.bin(1) File : EXEC_KERNEL_IMAGE0.bin File : boot.img File : recovery.img File : system.img File : oem.img File : persist.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x26 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WLTE Current File : SC9600_sharkl_5modcsfb_volte.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_WLTE_LTE Current File : LTE_DSP.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_WLTE_GGE Current File : SHARKL_DM_DSP.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : WARM_WLTE Current File : SC9600_sharkl_wphy_5mod_volte.bin Flashing now ... [FlashProc] : Error with code 0x00027E00A20000FF5D7E Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Flash Erase [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Erasig flash now, please wait ... ERROR : FLASH_FULL_FORMAT failed! Reconnect Power/Cable! |
