01-15-2016, 07:42 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: CHENNAI
Member: 1079392 Status: Offline Thanks Meter: 444 | Lava_SPARK_Nex1 SPD6531,read full flash and format done 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0017 0000 [0] Flash VEN : Winbond , W25Q64 [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info ExtInfo : Lava_SPARK Nex1_S005_20141204 Project : SC6531_OPENPHONE HWInfo : SC6531_OPENPHONE Compile : 12-04-2014 18:13:56 Set FileInfo : Model Vendor : LAVA Model Name : SPARKLE Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_La va_SPARK_Nex1_S005_20141204_12042014181356__LAVA-SPARKLE.bin Done! Elapsed: 00:02:03 Reconnect Power/Cable! Operation : Format File System [ v1.13 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0017 0000 [0] Flash VEN : Winbond , W25Q64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
