01-04-2011, 15:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 300 | Lc m501 cpu: Mt346c problem module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 16 sec Remove/Install battery now ! software version: 1.20 cable type: 1x12 (L12C) platform: MT: MT6205, MT6217-MT6235 searching adapter at COM9... adapter found, version: 4000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT346C result: Rx:3 Tx:7 time required: 15 sec Trying to Power-On... Power On ! Power On ! how to work with this cpu |
01-05-2011, 08:29 | #3 (permalink) |
Member: 430612 Status: Offline Thanks Meter: 300 | same story COM9 [VCP0] selected module v3.25 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 41 sec Remove/Install battery now ! |
The Following User Says Thank You to luyanda For This Useful Post: |
01-05-2011, 22:11 | #6 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
You must tell me now - what is the problem with your phone. Is it dead phone ? | |
01-06-2011, 18:58 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! if you read log- you can see that flash chip can not be detected. which means that phone need hardware reapir. resoldering or flash chip change |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
