12-04-2009, 22:50 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
12-04-2009, 23:18 | #4 (permalink) |
Freak Poster Join Date: Sep 2009 Location: www.telefony-nawigacje.pl
Member: 1122479 Status: Offline Thanks Meter: 22 | hi you write non stop the same thing dont be angry it's a joke phone is supported by infinity, under lcd i have 16 pins which look like connector to another lcd but six pins on the right have voltage 2,7- 2,8v so i solder each other and gnd to negative battery connector and nothing:/ if i have six pins which probably are tx or rx ,i must solder every one or maybe only two?? you know after i translate 4000 words i "vertu"ascent i'm very happy of my hard work and i want still working becouse of 20 chines phone in my office |
12-06-2009, 17:24 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! no need to post Micro USB picture, everyone knows how it look like. have you checked it's pins? problably Tx/Rx is located there, not as test points |
12-07-2009, 16:04 | #8 (permalink) |
Member: 1122479 Status: Offline Thanks Meter: 22 | hi i know about micro usb i want to atach phonto of testpoints not of micro usb so i checked with multimeter micro usb socket and there is no voltage between 2,7-2,8v:/ |
12-07-2009, 17:51 | #9 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,531 | Quote:
test same way availabe test points. Keep in mind that phone must be powered On from battery! | |
A8+ Need help - Pinout Needed | 2lits | Infinity-Box | 17 | 11-25-2009 02:36 |
Pinout for N95 RM-17 like origin pinout needed | ..::alexis::.. | Infinity-Box | 7 | 05-09-2008 17:54 |
Leady MM10 Pinout | MarvelXZ | Infinity-Box | 2 | 02-04-2008 17:49 |
leady Gt6107 pinout | Triminity | Infinity-Box | 1 | 10-28-2007 21:26 |
c520 pinout needed for fun | Lez | Motorola Old Legacy (EMMI) | 0 | 07-03-1999 20:53 |
