09-17-2008, 09:08
#1 (permalink)
Member: 91411
Sonork: 100.1584444 Thanks Meter: 372 | Leady X501 Unlocked with Pinfinity combination This is the smallest phone i ever handled ever.3 inches more or less.as you can see in my attached image its so small....anyways i just used pinfinity combination.pinfinder for automatic pin finding then infinity for unlocking process.... Quote:
software version: 1.14
cable type: 1x8 (L8A)
platform: MT: MT6205, MT6217-MT6228, MT6230
searching adapter at COM6...
adapter found, version: 2000
pins: 8, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed CPU: MT6219 result: Rx:2 Tx:3
time required: 5 sec
Power On !
saved: LEADY_X501_L8A_alfox
| BACKUP Quote:
COM6 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
Initializing[6219:8A01]...
CPU: MT6219
high speed boot enabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: SZMI19_05C_PCB01_GPRS_MT6219_EV.MAUI_05C_W0616_X50 1_ARABIC_V1.BIN
ver. sw2: MAUI.05C.W0616.X501.ARABIC.V1, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: flash[SZMI19_05C_PCB01_GPRS_MT6219_EV.MAUI_05C_W0616_X50 1_ARABIC_V1.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\flash_LeadyX501_[SZMI19_05C_PCB01_GPRS_MT6219_EV.MAUI_05C_W0616_X50 1_ARABIC_V1.BIN]_20080916-150223.B0M.bin
Finished, time used: 1791 sec
Remove/Install battery now !
UNLOCK Quote:
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6219
Connecting, wait...
Phone detected, wait...
Hardware: MT6219,E01
Date: 2004.06.18
Version: 1.1
Version: MAUI.05C.W0616.X501.ARABIC.V1
Version: SZMI19_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #1...
done
208 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1122
Finished, time used: 12 sec
RESTORE IMEI Quote:
Action: imei
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6219, E01
Hardware version: SZMI19_05C_HW
Software version: MAUI.05C.W0616.X501.
Software date: 2004.06.18
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono-CPU
new imei: 353099012736935
imei verified Ok
Finished, time used: 80 sec
Power off phone now !
