12-12-2015, 15:50 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Leagoo Lead 5 Firmware or Full Flash..? anyone has fw or full flash for this device..? i have stock rom which downloaded from needrom.com but i am getting 4032 error..and i backed up full flash.. it is 8gb.. preloader; preloader_rjk301_w_k510_leagoo_82.bin MT6582__LEAGOO_LEAD5__LEAGOO_Lead5__ALPS.KK1.MP1.V 2.10__Android_4.4.2__20150113_014334.ispff Code: Card found : S/N : 3EB438F8 , v0129 Chinese Miracle II [MTK module] v 1.38 Operation : Check / Read Info [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 56 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483847316505079A40A86E62DB DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505079A40A86E62DB [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : LEAGOO_Lead5 ProdName : LEAGOO_Lead5 ProdModel : LEAGOO_Lead5 Device : LEAGOO_Lead5 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 MODEM : BaseBand : MT6582_S00_RGK301_REDUCE_BP_W_C1_V0_0_3_S0903_1_wg_n EXTRA : LCD [0] : hx8389b_qhd_boe5p0_yns_a27 LCD [1] : hx8379c_fwvga_boe5p0_k510 LCD [2] : ili9806e_fwvga_boe5p0_k510 LCD Res : 0x0 TOUCH [0] : focaltech TOUCH [1] : GT9XX_3 CAM [0] : ov5648_mipi_raw CAM [1] : gc0329_yuv CAM [2] : ov5647_mipi_raw CAM [3] : gc5004_mipi_raw CAM [4] : hm5065_yuv CAM [5] : hm5040_mipi_raw CAM [6] : gc0328_yuv CAM [7] : gc2235_raw CAM [8] : ov5670_mipi_raw MODEM : rjk301_w_reduce_c1 LOCALE : en_US es_ES zh_CN zh_TW ru_RU en_SG en_IN en_ZA en_IE en_NZ mn_MN sw_TZ pt_BR ka_GE lo_LA hy_AM kk_KZ fr_FR ne_NP et_EE bn_IN az_AZ be_BY zu_ZA am_ET sl_SI af_ZA rm_CH fa_IR ur_PK ja_JP sr_RS fr_CA bn_BD de_LI ca_ES en_CA hi_IN de_CH it_CH de_DE fr_BE en_AU tr_TR it_IT ar_IL in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_BE zh_HK nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB Done! Elapsed: 00:00:32 Reconnect Power/Cable! Code: Scatter Load Ok , BaseBand : MT6582 , Project : rjk301_w_k510_leagoo_82 , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.38 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 56 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483847316505079A40A86E62DB DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:30 Reconnect Power/Cable! |
The Following User Says Thank You to LoveLess For This Useful Post: |
12-12-2015, 16:45 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | ROM, which you have not applicable for this phone, seems. That is reason, why CM2 can't boot it in FW flashing - it uses data from ROM during flashing. |
12-14-2015, 10:03 | #3 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
but the preloaders are same.. phone preloader and rom preloader, preloader_rjk301_w_k510_leagoo_82.bin preloader_rjk301_w_k510_leagoo_82.bin | |
