08-31-2017, 16:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | Leco Le 2 Pro X620 I m trying to format Leco Le 2 Pro X620 but it gives me an error. Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED SECURE_BOOT : DA_AUTH_REUIRED! Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Pls Help! |
09-01-2017, 17:10 | #5 (permalink) |
Member: 2157664 Status: Offline Thanks Meter: 43 | Selected the model, connected with volum up. Operation : Fix Unknown BaseBand [ v1.58 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007024 SECURE_BOOT : DA_AUTH_REUIRED! Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! |
09-01-2017, 17:11 | #6 (permalink) |
Member: 2157664 Status: Offline Thanks Meter: 43 | without any buttons pressed Operation : Fix Unknown BaseBand [ v1.58 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED SECURE_BOOT : DA_AUTH_REUIRED! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
09-01-2017, 20:50 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | ... And the question : What was the exact problem with phone, what you needed to do ? Reflash firmware ? Remove FRP ? Fix IMEI ? b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
09-04-2017, 17:19 | #9 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | |
09-05-2017, 22:02 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | First, try reflashing the phone. Tools : SP_Flash_Tool_exe_Windows_v5.1612.00.000_Sec LE2_X620_SPFT_ROM_HEXCNFN5601304221S Unpack SPFT, Unpack ROM, Start SPFT, press CTRL + ALT + S - Select DA Agent from SPFT folder\secureboot\DA_BR.bin - Select Scatter file from ROM folder - Select Auth file from SPFT folder\secureboot\auth_sv5_letv.auth Press DOWNLOAD and connect powered off phone, wait to finish. Boot the phone, check if baseband is okay. b.r. Alex
The Following 3 Users Say Thank You to Brka For This Useful Post: |
10-26-2017, 10:13 | #14 (permalink) | |
Freak Poster Join Date: May 2003 Location: Poland Age: 46
Member: 27843 Status: Offline Sonork: 100.1646294 Thanks Meter: 26 | Quote:
09-08-2021, 12:46 | #15 (permalink) |
Insane Poster Join Date: Apr 2020 Location: Mananjary
Member: 2955238 Status: Offline Thanks Meter: 6 | Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007024 SECURE_BOOT : DA_AUTH_REUIRED! Boot Error! |
